    Thermostatically Controlled Fan Confusion
    • brisksleeperundefined
      brisksleeper
      Up until now I've had my hotend fan on constantly and just set it up to be thermostatically controlled. I have it hooked up to Fan 1 (not Fan0) and have M106 P1 T45 S255 H1 in my config.g. Now, when I manually enter the temperature, the fan turns on and off when it reaches and falls below 45deg, respectively. But when I start a print and it gets to the desired temp, the fan doesn't turn on until I stop the print (when it's over 45). Any ideas on what's happening?
      PS: I tested a print as M106 P1 H-1. It was on at first, but turned off once the print started. Is it something in the slicer (I'm using Simplify3d)? I can't find anything that could override the fan control.
        It sounds to me that you also have Fan1 set up as the print cooling fan in your M563 command.
          brisksleeper
          Bingo! Thank you DC, you're the best!
