Not homing X on Delta build
Yes they all light up and switch as expected.
I think there must a fault in the endstop 0 circuit. It may be a simple as a blob of flux or other contaminant on the PCB, most likely either on the microcontroller pins (where it would be easy to see and remove with isopropyl alcohol), or under the endstop connector (where it would not be visible). If you would like to contact your supplier, I will authorise a replacement under warranty.
I can understand why firmware 1.19 is more sensitive to that fault than earlier versions, but not why 1.20RC4 hasn't restored it back to the previous behaviour.
David if I may this is on a 0.6 board so def not under warranty.
I'll remove it and give it a clean. But if it can only run FW 1.11 will it work with the smart effector?
It should be quite easy to lift the plastic bit on the header as well (small blade just to prise it up a little)
Correct, somehow I forgot that you can do that.
I've cleaned the board, even went as far as re-soldering the 2 pins still no different. Have tried several different older firmware options and the newest that will run is RepRapFirmware-1.13b, soon as I tried RepRapFirmware-1.14 got the same fault back.
1.14 is such a long time ago that I can't think what might have changed to trigger the fault.
As a workaround, you could try adding a 1K pullup resistor between the STP and +3.3V pins on that endstop connector.
I'm only using STP and GND
Tried the 1k resistor and it works.
Thank you very much for your time and patience, it's very much appreciated and have a Merry Christmas.
Paul
