    Can I use 'continue' in a ternary construct?
    Gcode meta commands
    • oliofundefined
      oliof
      Is the following valid?
      {exists(global.debug) && global.debug} ? echo 'foo' : continue
      If no, what would I use instead of continue?
      dc42undefined moth4017undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @oliof
        @oliof no, because continue is a command, not an expression. Use an if-statement instead.
        • moth4017undefined
          moth4017 @oliof
          @oliof thanks for asking , @dc42 is there a print to console function ?
          DocTruckerundefined 1 Reply Last reply Reply Quote 0
          • DocTruckerundefined
            DocTrucker @moth4017
            @moth4017 try the echo keyword in comditional gcode. Failing that M117 display message.
