    Macro to stop printing, run some code and then resume print
    Firmware installation
    • timmit99undefined
      timmit99
      I'm looking to mace a macro on my printer pause the current print, run a set of gcode commands that pulse a pin and delay, and then return to the print as if nothing has happened. The machine is a DuetWifi and DueX5
      I have created "Trigger2.g" in the "sys" folder and have added "M581 T2 S1 E2 C0" in config.g that will invoke trigger 2 on rising edge on E2 endstop regardless of print status. I have attached a switch to the E2 endstop connector on the dueX5 and when i have the "Trigger2.g" contain just
      M42 P100 S255
      G4 P10
      M42 P100 S0
      ```the pin is pulsed, however after adding more commands to the file the commands seem to be interlaced with the print commands and the print doesnt stop.
      [[language]]
      ;Switch to relative, lift Z 10 mm and return to absolute.
      G90
      G1 Z10
      G91
      G1 X100 Y300 F4800; Move to purge location
      ;Pulse to open the valve
      M42 P100 S255
      G4 P10
      M42 P100 S0
      G4 S60; Delay for 60 seconds
      ;Pulse to close the valve
      M42 P100 S255
      G4 P10
      M42 P100 S0
      G4 S5; Delay for pressure build up
      I'm stuck on how to proceed with pausing the print, running commands and then resuming the print properly.
      • fmaundefined
        fma
        Try to add a M400 command at the beginning of your macro…
        Frédéric
          Use M25 to pause the print, then do the M42 commands, then M25 M24 to resume the print.
          • timmit99undefined
            timmit99
            Resume with M25 or M24?
              M24.
