    Reprap fisher latest firmware for duet 0.6
    Firmware installation
    262
    • racitupundefined
      racitup
      It appears the latest firmware for duet 0.6 is here:
      https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
      i.e. 1.26.1
      I currently have:
      Firmware Name: RepRapFirmware for Duet
      Firmware Electronics: Duet 0.6
      Firmware Version: 1.23 (2018-12-24b1)
      Web Interface Version: 1.22.6
      Are there many/any changes I will have to do to the sys files for the new firmware?
      Do I just upload the RepRapFirmware.bin?
      I keep bricking prints because the nozzle heater control becomes very unstable which generates a heater fault. I thought I'd fixed it because the PID parameters didn't appear to be calibrated, but just bricked another print... I'm hoping new firmware will improve things.
      Also resurrect doesn't work properly even though I've attempted to set up a resurrect-prologue.g.
      Is the new firmware likely to fix these things?
      Thanks
      racitupundefined 3 Replies Last reply Reply Quote 0
      • racitupundefined
        racitup @racitup
        @racitup There do appear to be plenty of resurrect.g file changes since 1.23, so fingers crossed!
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-1.x-&-2.x#version-2051
        • racitupundefined
          racitup @racitup
          @racitup Just found this, sounds like I just update the firmware and everything should be fine. Only need to change files for v3, which isn't compatible with duet 0.6..
          https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#updating-from-older-firmware-versions
          • o_lampeundefined
            o_lampe
            Fingers crossed you'll fix the problem with an update.
            But I'd also check the thermistor and heater wiring for damaged connections.
            Especially the super-thin wires from the thermistor tend to break from vibration.
            • racitupundefined
              racitup @racitup
              @racitup said in Reprap fisher latest firmware for duet 0.6:
              For anyone else interested There is a bug affecting calibration after 2.02 (1.23), at least on a fisher delta with duet 0.6 anyway.
              I've posted the issue here:
              https://github.com/Duet3D/RepRapFirmware/issues/953
              I may try 1.26 to see if it prints okay, but definitely DO NOT use 1.26.1 (2.05.1) because it will clash the Z tower, as reported here:
              https://forum.duet3d.com/topic/34823/tower-clash-in-mesh-bed-compensation-fisher-delta
              casesolved-co-uk created this issue in Duet3D/RepRapFirmware
              closed [Bug]: Releases after 2.02 (RepRapFirmware.bin 1.23) broken calibration for delta on duet 0.6 #953
              chrishammundefined racitupundefined 2 Replies Last reply Reply Quote 0
              • chrishammundefined
                chrishamm administrators @racitup
                @racitup I just fixed the legacy configtool in v3.4.1 for your config scenario. Please note that we don't really support firmware 1.xx or the Duet 0.6 any more.
                Duet software engineer
                racitupundefined 1 Reply Last reply Reply Quote 0
                • racitupundefined
                  racitup @chrishamm
                  @chrishamm much appreciated thanks
                  • racitupundefined
                    racitup @racitup
                    @racitup It turns out I had deployprobe.g and retractprobe.g in sys which was causing the issue.
                    v1.26.1 (2.05.1) now appears to be working okay.
