    Extruder motor stops during print…
    11.3k
    • UltiBotsundefined
      UltiBots
      Hi All -
      We have a printer where the extruder motor stops after an hour or so of printing. What are some methods to troubleshoot this?
      After M999 or a power cycle the extruder works again.
      Thanks - Brad
        When the fault occurs, does the tool heater still show Active, or does it show a heater fault?
        Are there any error messages displayed in the GCode Console page of DWC, for example a Heater Fault message, or a "no tool selected" message?
        • UltiBotsundefined
          UltiBots
          The heater still shows active, with no error messages in the GCode Console.
          Going to swap extruders and test.
          • ofloveandhateundefined
            ofloveandhate
            OP here. d300vs with firmware RepRapFirmware for Duet Ethernet version 1.19.2 (2017-09-01), Duet Ethernet 1.0.
            repeated failures of the following kind:
            the extruder stops responding to moves, with no error message. only way to get it responsive is to M999 or power cycle.
            d300vs thread here: http://forum.ultibots.com/viewtopic.php?f=59&t=297
              I suggest you start by upgrading the firmware to 1.20. It provides better monitoring of the stepper drivers, so it may warn you if the driver is reporting an unusual status.
              If the issue recurs, after it has happened and before rebooting, please send M122 to get a diagnostic report. Also send M906 without any parameters and confirm that the current is still set correctly.
                ofloveandhate
                ok, thanks. will report back in a few days.
                  ofloveandhate
                  another failure
                  M906
                  Motor current (mA) - X:1000, Y:1000, Z:1000, E:400:400:400:400:400:400:400:400:400, idle factor 30%
                  M122
                  Used output buffers: 3 of 32 (9 max)
                  RepRapFirmware for Duet Ethernet version 1.20 running on Duet Ethernet 1.0
                  Board ID: 08DDM-9FAMU-JW4S4-6JKD8-3SD6L-TMXMS
                  Static ram used: 11992
                  Dynamic ram used: 98816
                  Recycled dynamic ram: 3880
                  Stack ram used: 1216 current, 8448 maximum
                  Never used ram: 7936
                  Last reset 27:23:06 ago, cause: power up
                  Last software reset at 2018-01-26 12:31, reason: User, spinning module GCodes, available RAM 10464 bytes (slot 0)
                  Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                  Error status: 0
                  Free file entries: 10
                  MCU temperature: min 41.0, current 41.2, max 60.2
                  Supply voltage: min 23.8, current 24.4, max 24.9, under voltage events: 0, over voltage events: 0
                  Driver 0: standstill, SG min/max 0/1023
                  Driver 1: standstill, SG min/max 0/1023
                  Driver 2: standstill, SG min/max 0/1023
                  Driver 3: standstill, SG min/max 0/1023
                  Date/time: 2018-01-27 15:56:14
                  Slowest main loop (seconds): 0.607014; fastest: 0.000045
                  MaxReps: 5856, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 2357420531ms, Underruns: 0, 1
                  Scheduled moves: 0, completed moves: 0
                  Bed compensation in use: none
                  Heater 0 is on, I-accum = 0.0
                  Heater 1 is on, I-accum = 0.5
                  Segments left: 0
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  State: 5
                  HTTP sessions: 1 of 8
                  Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  what should i try next? i have not yet tried the other extruder pins on my board. i also have a wifi i can try, but that's pretty invasive, and it makes connecting a PITA.
                    ofloveandhate
                    ok, so i tried something. with the machine in its errored state, i swapped the extruder motor pins to E1, instead of E0. then, i made a new tool in the web interface.
                    switching to the new tool on the other pins allowed me to extrude! then, as a sanity check, i swapped the pins back to E0, changed back to the original tool, and was unable to extrude. ok, i am not insane. switch to new tool on E1, extruding is ok.
                    i think i will try printing on E1.
                      ofloveandhate
                      i printed on E1 last night, to no avail. still failed. i am unable to connect to the printer, "due to the duet firmware". wish i had a screencap of the page – did a refresh, and now get nothing. i am unable to connect to the printer through any other means. my normal fallback of repetier host, simplify3d, and all other programs fail to connect.
                      i have now wasted about two kg of plastic due to this problem...
                        ofloveandhate
                        so, i swapped boards to my wifi board, with firmware 1.19.2. another failure.
                        i updated on the wifi to 1.20, and am reprinting now.
                          ofloveandhate
                          another failure, on my wifi, 1.20. we can safely say:
                          • either neither of my duet boards are defective, or both are
                          • if this is a firmware problem, it exists in 1.19.2 and 1.20
                          i additionally believe that
                          • we can rule out my wiring as a problem. otherwise, when i switched E0 to E1, the extruder would not have moved without a restart. however, if my wiring is causing this fault, it should be firmware detectable… ideally
                          one problem i have observed is that the firmware is unable to detect if the extruder motor comes disconnected. you can unplug, and replug, no errors. should this not be observable?
                            ofloveandhate
                            is this the same problem as i am experiencing?
                            https://community.ultimaker.com/topic/4733-print-stops-or-fails-halfway-through/
                              ofloveandhate
                              it seemed so at first, but no, my fans work fine. that post was about heat creep, not the motor stopping.
                                Does extrusion stop at the same point in the print each time?
                                The stepper drivers on the Duet can in theory detect when a motor wire is disconnected, but in practice we found it gave false positives, so I disabled that facility. If I can find a way to filter out the false positives, I will enable it again.
                                  ofloveandhate
                                  another thought i had – maybe i should put a fan on the duet? is the board overheating?
                                  https://www.duet3d.com/wiki/Connecting_and_configuring_fans
                                    ofloveandhate
                                    no, it is not the same point every time.
                                      ofloveandhate
                                      here's a snippet of what my gcode looks like:
                                      G1 X-9.773 Y20.202 E0.0240
                                      G1 X-8.049 Y19.083 E0.0845
                                      G1 X-7.228 Y18.592 E0.0393
                                      G1 X-5.829 Y17.806 E0.0660
                                      G1 X-2.005 Y15.805 E0.1774
                                      G1 X-1.749 Y15.664 E0.0120
                                      G1 X-0.741 Y15.031 E0.0489
                                      G1 X-0.182 Y14.575 E0.0297
                                      G1 X0.225 Y14.087 E0.0261
                                      G1 X0.746 Y12.742 E0.0593
                                      G1 X0.847 Y12.526 E0.0098
                                      G1 X0.864 Y12.365 E0.0066
                                      G1 X0.745 Y10.941 E0.0588
                                      G1 X0.342 Y9.133 E0.0761
                                      G1 X-0.212 Y7.194 E0.0829
                                      G1 X-1.216 Y3.878 E0.1424
                                      G1 X-1.686 Y2.198 E0.0717
                                      G1 X-1.997 Y1.061 E0.0484
                                      G1 X-2.338 Y-0.306 E0.0579
                                      G1 X-2.657 Y-1.687 E0.0582
                                      G1 X-3.138 Y-4.143 E0.1029
                                      G1 X-3.300 Y-5.092 E0.0396
                                      G1 X-3.519 Y-6.570 E0.0614
                                      G1 X-3.767 Y-8.725 E0.0892
                                      G1 X-3.921 Y-10.510 E0.0736
                                      G1 X-4.038 Y-12.900 E0.0984
                                      G1 X-4.060 Y-14.016 E0.0459
                                      G1 X-4.047 Y-16.295 E0.0937
                                      G1 X-3.986 Y-17.935 E0.0674
                                      G1 X-3.894 Y-19.398 E0.0602
                                      G1 X-3.771 Y-20.858 E0.0602
                                      so it is a sequence of short extrusion moves the whole file. no long linear extrudes, just this.
                                        ofloveandhate
                                        here are my four attempts at 'seepferdchen'
                                          ofloveandhate
                                          another thought: should i prefer absolute or relative extrusions? i have only been using relative through this whole process.
                                            ofloveandhate
                                            i am starting to think there is a bug in the reprap firmware, in the part that processes relative extrusion distances. i printed the same model, same supports and all settings, last night. only change was that in simplify3d, i switched to absolute extrusion.
                                            ok, there was another difference that i should have not let happen, and that was that i printed this one without the https://www.thingiverse.com/thing:2567240 bottom corner plates.
                                            i am re-printing the same file now. if it fails again, then we know that the relative / absolute distances had nothing to do with my problem. if it succeeds, we have stronger evidence that it is a firmware bug.
