[3.5.0-rc1/rc3] Issue with Probe offsets
I am not sure if this is user error or a bug...
EDIT: It was user error. Turns out my Z-axis lost steps during initial Z-homing. It was almost unnoticeable and I only found out by reconfiguring my whole setup from the ground up.
I noticed that the Z-Probe offset is not applied when the Z0 Datum has not been established. On my Printer without the Z0 datum probed the nozzle touches the bed at Z=0.35mm, so there should be no big difference between Z0 right after booting/homing and the probed Z0 datum.
I use the euclid probe so the probe switch extends quite far below the nozzle when deployed.
I have to use a very large dive height to establish the Z0 datum after booting/homing, in order to prevent the printer crashing the probe into the bed at full speed. With a dive height of 15mm the probing move still starts with the probe at about 3mm over the bed . After the first point is probed, the probe offsets are applied/respected. I would expect the probe offsets to be always applied when a probing move is done.I think I noticed this problem shortly after upgrading to RRF 3.5 from RRF 3.4.6 initially I did not think much of it and fixed it by setting the dive hight to 15mm in config.g and adjusting the dive height to a lower value after probing the first point. But while streamlining my probing routines I stumbled on this again...
Duet3 6HC , RRF 3.5-rc3
This is my probe configuration:
M558 K0 P8 C"^124.io1.in" H15 F120 T42000 A5 S0.03 G31 X0 Y26 Z10.55
This is my bed.g
;deselect tools ;echo "bedfourscrews" M671 X-41:495.5:495.5:-41 Y353:353:23:23 S10 ;lead screw positions and maximum allowed correction S in mm M561 ;clear any bed transform M290 R0 S0 ;clear babystepping G29 S2 ;disable mesh compensation if sensors.probes[0].value[0]<1000 ;check if probe is deployed M401 ;deployprobe ; probe at each corner of the bed M558 K0 H15 G30 K0 P0 X{(move.axes[0].min+45)} Y{(move.axes[1].max-10)} Z-99999 ; probe near a leadscrew G30 K0 P1 X{(move.axes[0].max-20)} Y{(move.axes[1].max-10)} Z-99999 ; probe near a leadscrew G30 K0 P2 X{(move.axes[0].max-20)} Y{(move.axes[1].min+20)} Z-99999 ; probe near a leadscrew G30 K0 P3 X{(move.axes[0].min+45)} Y{(move.axes[1].min+20)} Z-99999 S4 ; probe near a leadscrew and calibrate 4 motor while move.calibration.initial.deviation >= 0.03 ; perform additional tramming if previous deviation was over 0.01mm if iterations = 5 abort "Probing cycle cancelled! Too many calibration attempts or inconsistent probe readings" else M558 H0.5:0.2 ; adjust probe dive height G30 K0 P0 X{(move.axes[0].min+40)} Y{(move.axes[1].max-10)} Z-99999 ; probe near a leadscrew G30 K0 P1 X{(move.axes[0].max-15)} Y{(move.axes[1].max-10)} Z-99999 ; probe near a leadscrew G30 K0 P2 X{(move.axes[0].max-15)} Y{(move.axes[1].min+20)} Z-99999 ; probe near a leadscrew G30 K0 P3 X{(move.axes[0].min+40)} Y{(move.axes[1].min+20)} Z-99999 S4 ; probe near a leadscrew and calibrate 4 motor M558 H2:0.5 ; reset probe dive height echo "Plattform calibration successfull. Deveation between points: " ^ move.calibration.initial.deviation ^ " mm"
how would the machine know where the head is so it can apply probe offsets before homing? Is there something I am missing?
@oliof said in [3.5.0-rc1/rc3] Issue with Probe offsets:
The machine is homed to Zmax after booting. Then the probing routine is started.
undefined MaxGyver marked this topic as a question
undefined MaxGyver has marked this topic as solved
