    Unable to connect duet to wifi
    • tronmanundefined
      tronman
      I'm having trouble with being able to control/send commands to my duet wifi 2. Sidenote: I've been using the RepRap Firmware config tool to set up the files in the sys directory on the SD card. The other directories I have I got from downloading the 3.4.6 file from https://github.com/Duet3D/RepRapFirmware/releases.
      I've used both YAT and Putty to connect to the duet. Despite using the suggested driver, Yat gives me the following error, even before I send any commands:
      <SO><DLE>Q[Warning: "80h 6Ah" is a byte sequence outside the Unicode basic multilingual plane (plane 0)! Only Unicode plane 0 is supported by .NET Framework and thus YAT (yet).]
      Due to an inability to locate the IP of the duet, I tried setting a static IP for the duet in RRF config, to access the duet via Putty using SSH, unsuccessfully. When I tried using a serial connection instead, a terminal opened up, but I was unable to type anything, and the terminal had a string of unrecognizable characters.
      I noticed the wifi LED hasn't turned on during any of these attempts. After pinging the static IP via powershell, I received a 'request denied' error. I am aware that the duet only uses 2.4 GHz, so I ensured my network has separate bands for 2.4 and 5 GHz.
      I've also noticed the RRF config setup does not provide me with all the directories I've seen in youtube tutorials and Duet setup guides, so I'm wondering if that might be a reason.
      This is the list of directories I believe I'm supposed to have. The bolded ones are the ones I'm missing
      ├── filaments
      ├── firmware
      │ ├── Duet2CombinedFirmware.bin
      │ └── Duet2_SDiap32_WiFiEth.bin
      ├── gcodes
      ├── macros
      ├── sys
      │ ├── bed.g
      │ ├── config.g
      │ ├── config.json
      │ ├── homeall.g
      │ ├── homex.g
      │ ├── homey.g
      │ ├── homez.g
      │ ├── pause.g
      │ ├── resume.g
      │ ├── sleep.g
      │ ├── stop.g
      │ ├── tfree0.g
      │ ├── tpost0.g
      │ └── tpre0.g
      └── www
      ├── DuetAPI.xml
      ├── css
      │ ├── Accelerometer.5c60999b.css.gz
      │ ├── GCodeViewer.9597b317.css.gz
      │ ├── HeightMap.4d390d72.css.gz
      │ ├── ObjectModelBrowser.c5e13b42.css.gz
      │ ├── OnScreenKeyboard.7f43fe4b.css.gz
      │ └── app.ce075a4e.css.gz
      ├── favicon.ico.gz
      ├── fonts
      │ ├── materialdesignicons-webfont.147e3378.woff
      │ ├── materialdesignicons-webfont.147e3378.woff.gz
      │ ├── materialdesignicons-webfont.174c02fc.ttf.gz
      │ ├── materialdesignicons-webfont.64d4cf64.eot.gz
      │ ├── materialdesignicons-webfont.7a44ea19.woff2
      │ └── materialdesignicons-webfont.7a44ea19.woff2.gz
      ├── img
      │ └── icons
      │ ├── android-chrome-192x192.png.gz
      │ ├── android-chrome-512x512.png.gz
      │ ├── android-chrome-maskable-192x192.png.gz
      │ ├── android-chrome-maskable-512x512.png.gz
      │ ├── apple-touch-icon-120x120.png.gz
      │ ├── apple-touch-icon-152x152.png.gz
      │ ├── apple-touch-icon-180x180.png.gz
      │ ├── apple-touch-icon-60x60.png.gz
      │ ├── apple-touch-icon-76x76.png.gz
      │ ├── apple-touch-icon.png.gz
      │ ├── favicon-16x16.png.gz
      │ ├── favicon-32x32.png.gz
      │ ├── msapplication-icon-144x144.png.gz
      │ ├── mstile-150x150.png.gz
      │ └── safari-pinned-tab.svg.gz
      ├── index.html.gz
      ├── js
      │ ├── Accelerometer.4a8a402b.js.gz
      │ ├── Accelerometer.4a8a402b.js.map.gz
      │ ├── GCodeViewer.95d3cd80.js.gz
      │ ├── GCodeViewer.95d3cd80.js.map.gz
      │ ├── HeightMap.a082b8e6.js.gz
      │ ├── HeightMap.a082b8e6.js.map.gz
      │ ├── ObjectModelBrowser.0b9b2798.js.gz
      │ ├── ObjectModelBrowser.0b9b2798.js.map.gz
      │ ├── OnScreenKeyboard.a880bca8.js.gz
      │ ├── OnScreenKeyboard.a880bca8.js.map.gz
      │ ├── app.24acd1b2.js.gz
      │ └── app.24acd1b2.js.map.gz
      ├── manifest.json.gz
      ├── precache-manifest.a4ab8f573fcc203b798fa7d11eee39d5.js.gz
      └── service-worker.js.gz
      This is my first time working with the duet, any suggestion on what I might do to resolve this issue would be great!
      • T3P3Tonyundefined
        T3P3Tony administrators @tronman
        @tronman The error you are getting in YAT is not one i have seen before. How are you running it, that error indicates something very different with how YAT is being run that compared to (for example) a default install on windows)
        www.duet3d.com
        tronmanundefined 1 Reply Last reply Reply Quote 0
        • tronmanundefined tronman marked this topic as a question
        • tronmanundefined
          tronman @T3P3Tony
          @T3P3Tony I downloaded and updated the suggested driver from GitHub, connected the duet to my Windows 11 laptop, and created a new terminal in YAT with the selected COM port.
          I pretty much followed the steps in this video, except I had to manually install the driver through device manager:
          https://www.youtube.com/watch?v=TxfEbUuKDyo
          Not sure if I mentioned this in my last post, but The Diag LED turns and stays on as soon as I connect the duet to my laptop. Is this an indication of incorrect firmware installation?
          • tronmanundefined
            tronman @tronman
            I was able to resolve this issue by redownloading the duet driver, erasing and re-flashing the firmware using BOSSA.exe. I believe the driver might not have properly been installed last time. Now I'm able to send commands through YAT!
            T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
            • tronmanundefined tronman has marked this topic as solved
            • T3P3Tonyundefined
              @tronman thanks for confirming the fix!
              www.duet3d.com
