    M486 S parameter length? Anyone from PrusaSlicer here?
    Documentation
    • paralepsisundefined
      paralepsis
      Using PrusaSlicer and RRF flavor of object descriptions, I have a gcode file that looks like this:
      486 S0 A"gaslands-dungeonsticks-85perc-barrier-notched.stl"
      M486 S-1
      M486 S1 A"gaslands-dungeonsticks-85perc-barrier-shot.stl"
      M486 S-1
      M486 S2 A"gaslands-dungeonsticks-85perc-barrier-whole.stl"
      M486 S-1
      M486 S3 A"gaslands-dungeonsticks-85perc-barrier-sloped.stl"
      M486 S-1
      M486 S4 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 1)"
      M486 S-1
      M486 S5 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 2)"
      M486 S-1
      M486 S6 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 3)"
      M486 S-1
      M486 S7 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 4)"
      M486 S-1
      M486 S8 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 5)"
      M486 S-1
      M486 S9 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 6)"
      M486 S-1
      M486 S10 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 7)"
      M486 S-1
      M486 S11 A"gaslands-dungeonsticks-85perc-barrel-split.stl (Instance 8)"
      I get the following on console:
      Error: in GCode file line 912 column 62: M486: string too long
      Error: in GCode file line 914 column 62: M486: string too long
      Error: in GCode file line 916 column 62: M486: string too long
      Error: in GCode file line 918 column 62: M486: string too long
      Error: in GCode file line 920 column 62: M486: string too long
      Error: in GCode file line 922 column 62: M486: string too long
      Error: in GCode file line 924 column 63: M486: string too long
      Error: in GCode file line 926 column 63: M486: string too long
      Yeah, those are long, I get it :).
      I imagine there's somewhere in the docs that max. string lengths are mentioned, but not here: M486. It might be worth capturing here?
      More pragmatically, it would be awesome if PrusaSlicer would truncate somehow to avoid the errors (I can rename myself in the future I guess). Is anyone here in a good position to make such a tweak?
      Thanks!
      Rob
      Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
        dc42 administrators @paralepsis
        @paralepsis there is currently a limit of 50 characters for the lengths of object names. In RRF 3.5 a more dynamic storage mechanism is used for object names, and this has allowed me to increase the maximum length to 100 in the next 3.5 build.
        • oliofundefined
          oliof
          I don't think PrusaSlicer devs read here or care much about RRF compatibility. You may be able to cook up a post processing script that extracts names, shortens them to say 48 characters, and adds a two digit numeric index. Note that there is an upper limit to the number of objects you can control as well.
          paralepsisundefined 1 Reply Last reply Reply Quote 0
            paralepsis @oliof
            @oliof Thanks. Might make sense to have the # of objects documented with M486 also, so it isn't a surprise?
            I tend to use the location of the objects in the overhead view for canceling anyway, so the errors are mostly a distraction :).
            • oliofundefined
              oliof @paralepsis
              @paralepsis documentation of the object limits is a good idea, one for @droftarts
