TEMP error please help asap :)
During the printing process I got an error "Heater 0 fault: failed to read sensor: sensor open circuit".
Temp sensor wiring looks good. DWC shows 2000C temperature. Is there a way to resume the printing process without restarting the printer? I just really want to finish the print job
2000C means open circuit, the printer won't continue until this is fixed. If your wiring looks good, it can be a failed crimp or loose plug, or it's an internal stress fracture if your thermistor wire goes from toolhead to control board.
@oliof ahh, that's true... there must be an internal fracture in the wire, another sensor is working good...
