many many hiccups (thousands)
Any progress on this issue ?
I don't know if the hiccup issue is still being looked into or if it has been shelved. I just ran a 6 hr print using 3.5.1 and I am still seeing the same issues. Here is my m122 for the tool board that did the printing. Note the 'hiccups 27753'
m122 b22
Diagnostics for board 22:
Duet TOOL1LC rev 1.1 or later firmware version 3.5.1 (2024-04-19 14:42:41)
Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
All averaging filters OK
Never used RAM 3104, free system stack 71 words
Tasks: Move(3,nWait 7,2.2%,85) HEAT(2,nWait 6,8.9%,91) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,2.5%,71) CanClock(5,nWait 1,0.6%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,90.6%,53) MAIN(1,running,38.8%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,122.4%,112), total 266.0%
Owned mutexes:
Last reset 97:43:37 ago, cause: software
Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 1
Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task Freestk 129 bad marker
Stack: 00000544 00022ffc 00019b65 20003134 00016cff 20003134 000163d1 20000ed0 00000000 00000001 00008275 200071c8 200071c8 200071e0 00000000 20000f50 00011647 000223b8 00022474 00021ac8 00019b05 200071c8 200071c8 20000f50 000083ed 200071d8 000009c7
Driver 0: pos 0, 830.0 steps/mm, standstill, SG min 0, read errors 10, write errors 0, ifcnt 225, reads 7857, writes 3, timeouts 32, DMA errors 0, CC errors 0, failedOp 0x6a, steps req 0 done 73029969
Moves scheduled 394767, completed 394767, in progress 0, hiccups 27753, segs 33, step errors 0, maxLate 1 maxPrep 495, maxOverdue 136, maxInc 71, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
Peak sync jitter -1/4, peak Rx sync delay 272, resyncs 0/0, no timer interrupt scheduled
VIN voltage: min 17.7, current 24.4, max 24.5
MCU temperature: min 32.8C, current 36.1C, max 54.4C
Last sensors broadcast 0x00000004 found 1 26 ticks ago, 0 ordering errs, loop time 0
CAN messages queued 1831836, send timeouts 0, received 2249695, lost 0, errs 0, boc 0, free buffers 18, min 17, error reg 0
dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 561, adv 35643/74674
Accelerometer: LIS3DH, status: 00
I2C bus errors 0, naks 0, contentions 0, other errors 0
=== Filament sensors ===
Interrupt 5726621 to 0us, poll 5 to 2912us
Driver 0: ok -
Can you share a video of the printer in action?
@Phaedrux, while not impossible, I don't really know what I am doing. Could you give me a hint as to what you expect to see? There is no apparent (at least to me) difference in printer behaviour between a printer that shows hiccups vs one that doesn't produce hiccups. I don't know if maybe one would see choppy motion for example ... but there is no hint of choppiness.
