Duet 2wifi push GCODE files only 1kb/s
I'm having a problem it's been going on for a long time and I've tried a lot of things to no avail. I've changed many class 10 memory cards and all new ones from sandisk, every time the same upload speed is only 1kb/s and the motherboard is right next to my router 0.5m with no cover in between. I've tried many versions of firmware and flashed the motherboard but still have the problem. I prepared a 12mb file and changed it to .dummy and on the first two seconds the upload speed was 200kb/s then immediately went to 10kb/s then to 1-2kb/s. After a while it will say upload failed.
I also tried uploading a gcode file of less than 1mb, and although the speed was still only 1kb/s, I found that when it showed uploading to 100%, it started uploading from 1% again and by then the speed had dropped to 500b/s. Then after a few tens of seconds it showed that the upload had failed! I have not been able to use my printer for a long time because this motherboard has not been able to upload my files, It used to work fine and to my great satisfaction, I don't know why all of a sudden it started not uploading files!If you have any suggestions I would like to try them!
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later + DueX5
Board ID: 0JD0M-9P61A-J8PS8-6JTD6-3SJ6L-TUSGU
Used output buffers: 1 of 26 (12 max)
Static ram: 23896
Dynamic ram: 75728 of which 144 recycled
Never used RAM 12312, free system stack 184 words
Tasks: NETWORK(ready,12.1%,246) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,85.1%,408) IDLE(ready,2.7%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:27 ago, cause: software
Last software reset at 2024-02-25 23:34, reason: User, GCodes spinning, available RAM 14708, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 39.1, current 39.9, max 40.1
Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min n/a
Driver 6: standstill, SG min n/a
Driver 7: standstill, SG min n/a
Driver 8: standstill, SG min n/a
Driver 9: standstill, SG min n/a
Driver 10:
Driver 11:
Date/time: 2024-02-26 19:00:21
Cache data hit count 991818318
Slowest loop: 6.39ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.3ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== DueX ===
Read count 1, 2.20 reads/min
=== Network ===
Slowest loop: 62.05ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
= WiFi =
Interface state: active
WiFi firmware version 1.27
WiFi MAC address 10:5:
WiFi Vcc 3.34, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 21976
WiFi IP address 192.16
WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
@Yapeng I see you already have a thread for this issue. please don't open multiple threads for the same issue. I am looking this one.
https://forum.duet3d.com/topic/30429/slow-upload-speeds-using-web-interface/12
