    1LC v1.2 rev-a not mentioned
    Documentation
    • Exerqtorundefined
      Exerqtor
      I've noticed that there ain't any information about the 1LC v1.2a, from a visual inspection it looks like it's only grounded mounting points (with the related R59-R62 resistors) and silkscreen that's the difference between v1.2 and v1.2a?
      • Exerqtorundefined Exerqtor marked this topic as a question
        droftarts administrators @Exerqtor
        @Exerqtor One for @T3P3Tony.
        • T3P3Tonyundefined
          T3P3Tony administrators @droftarts
          @Exerqtor
          I have updated the documentation to cover this, thanks! This was a small revision to v1.2 to bring in the changes that we made for version 1.3, other than the mounting hole changes.
          • Provided a path to ground, via 100K resistors from the mounting holes to make it easier for static charge build up on the if the Toolboard is mounted on the Hemera XS
          • Changed to higher power protection resistors for the thermistor inputs to better resist ESD/short from thermistor to 24V.
          • Changed the circuit around the VSSA fuse to make it more robust to ESD events.
          www.duet3d.com
          • Exerqtorundefined Exerqtor has marked this topic as solved
