    Duet 3 fried
    1.2k
    • new_to_me901undefined
      new_to_me901 @dc42
      @dc42 We did not actually extend the thermocouple wiring, so it seems like that isn't the culprit.
      I will check for what you advise when I get back to the workspace later today and let you know.
      We started using these boards more or less than 2 years ago, from filastruder a distributor in the US.
        dc42 administrators @new_to_me901
        @new_to_me901 we may be able to suppy a refurbished board to you. Please email sales@duet3d.com with your details including a link to this thread.
        new_to_me901undefined 1 Reply Last reply Reply Quote 0
        • NeoDueundefined
          NeoDue @dc42
          @dc42 Out of curiosity: is it possible from your experience to fry a chip that much as it is visible from the last picture in post 1 with ESD currents alone? I have seen numerous failures from ESD from invisble but dead components to exploded ones - but never a chip housing softened and melted like that. I always thought ESD discharges are too fast to melt plastics like that, hence the question.
            dc42 administrators @NeoDue
            @NeoDue said in Duet 3 fried:
            I don't believe that the energy in a "normal" ESD would be enough to fry a chip in that way directly; but it may trigger a failure mode in the chip that causes it to draw a lot of power, or that subjects another component to excessive voltage. In particular, small 3.3V linear regulators usually have an absolute maximum input voltage rating of 6.5V and any higher causes a breakdown that causes them to draw a large current.
            We know that ESD can directly fry small (0402 size) resistors.
            NeoDueundefined 1 Reply Last reply Reply Quote 0
            • NeoDueundefined
              NeoDue @dc42
              @dc42 Sure - secondary effects... I completely ignored those. Thanks! My knowledge in that respect is getting somewhat rusty... still thinking in THT or (Mini)MELF dimensions here 😉
                droftarts administrators @new_to_me901
                @new_to_me901 By the sounds of it, you also need to replace the thermocouple daughterboard, particularly as you say it has always given you trouble.
                I would think you could test it with your spare 6HC without damaging it, but only test as described here: https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_thermocouples#troubleshooting specifically
                If you have difficulty getting correct readings from the thermocouple board, try connecting a wire link between the two terminals of the terminal block instead of a thermocouple. This should produce a room temperature reading.
                  new_to_me901 @dc42
                  @dc42 wow thank you so much, I will do that! I got caught up with some other things on Wednesday and am now out of town. I'm returning next week and will pick back up on testing. I've already got the new duet3, just want to make sure all components are safe before hooking it all back up.
                  @droftarts when we originally started using the daughterboard a year ago and ran into these problems, I actually tried other daughterboards on hand and got the same result. I also tried other duet boards with these daughterboards, and same results. So going forward, even if this heater still works, we're actually planning to change the sensor to a thermistor in order to bypass the daughterboard altogether. I may try these steps anyways though, just to see what it's current condition is... Thanks for the advice!
                    new_to_me901 @dc42
                    @dc42 I have checked this and there is not short between the heater and the duet. I have also tested each individual component separately, and they all still work. Excepting the thermocouple daughterboard, we are just paying it safe and buying a new one. So still not sure exactly what happened here.
                    I am rebuilding with all of the tips in mind shown here. Plastic washers between the screw and board, and the board is mounted to plastic frame now. I have removed the peltier cooler from being controlled by the board altogether and am using a separate control board for this. I have docked it all in a computer case with adequate airflow and a fan to avoid dust. Hopefully all these combined will keep me good to go going forward!
                    Thank you to you and @NeoDue for all your help identifying points of improvement going forward. I appreciate it.
                    NeoDueundefined 1 Reply Last reply Reply Quote 1
                    • NeoDueundefined
                      NeoDue @new_to_me901
                      @new_to_me901 Then I cross my fingers your machine will run again soon 🙂
