[3.4.6] Odd behaviour of rotary axis
Hi gents,
In the past, when I put M350 before M92, it uses the microstepping value to calculate the real steps per unit. I could change the microstepping without having to change M92, too.
But for a rotary axis, I have to set it with the final value?M584 A4 R1 ; set drive mapping M350 A4 I0 ; configure microstepping w/o interpolation M92 A{200*4} ; set steps per turn
Another thing I noticed was the Object model.
Inmoves.rotation.angle
the value was always 0, although it showed the correct value in DWC.
Am I on the wrong path? I want to use several relative moves, but then query the OM to find out absolute position. -
@o_lampe Found out, it has the same behaviour in linear mode...must've been a general change I've missed?
@o_lampe said in [3.4.6] Odd behaviour of rotary axis:
Are you saying that this does not work in 3.4.6?
For the OM field this was fixed recently:
The values of the fields of move.rotation in the object model were incorrect, typically zero even if G68 had been used
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC
@T3P3Tony said in [3.4.6] Odd behaviour of rotary axis:
At least it doesn't work in my specific case:
I've modified a working config.g to test the rotary motor only. Maybe I erased too much and the missing information messes up the setting?
Here's the whole config:
config.gHmm, I haven't set any printer kinematics with M669, but which one would I choose with only a rotary motor on axe A?
@o_lampe can you try sending M92 and M350 in the console to report the existing settings, then change the microstepping for the axis using M350 and confirm that the steps/mm changes.
@T3P3Tony I did and it works.
The problem sat in front of the keyboard. Me thinking I only had to set full steps per turn with M92.
But it always was 200 x microstepsThanks for taking your time
