    Duet 3 6HC and Raspberry Pi 5?
    • bug2k22undefined
      bug2k22
      I am unable to get my Raspberry Pi 5 to boot with either the lite or gui version of the Duet Raspberry Pi images, is this a supported configuration? The red led (on the pi) turns solid green but there is no activity, with wired networking connected there is no light on the network port.
      If I write the sd card with any of the images from the Raspberry Pi website, they boot fine and networking works correctly.
        jay_s_uk @bug2k22
        @bug2k22 use the images from here https://forum.duet3d.com/topic/34825/new-experimental-duetpi-bookworm-builds-available
        bug2k22undefined 1 Reply Last reply Reply Quote 0
        • bug2k22undefined
          bug2k22 @jay_s_uk
          @jay_s_uk said in Duet 3 6HC and Raspberry Pi 5?:
          Thanks for the link. Is there any difference in using the duet images compared with installing Raspberry Pi OS Lite and then following the install instructions in the documentation?
          • chrishammundefined
            chrishamm administrators @bug2k22
            @bug2k22 The Duet3D images are based on the official RPi OS so it's definitely an easier choice. A few differences I can think of:
            • Different boot screen*
            • Auto-setup of correct TfrRdy pin in DSF config (needed on RPi 5 only)
            • Preinstalled packages from unstable package feed
            • Auto-start of DWC in full-screen mode*
            • A couple of extra preinstalled packages including required dependencies like AppArmor
            • Only applies to GUI image
            Duet software engineer
