    Duet3D for 12V solenoid and 7V servo motor?
    • Arminasundefined
      Arminas
      I am familiar with Duet3D, but I have no idea about any other boards. I am looking for the most simple board to work with 1 pcs solenoid (12 V, 2 A) and simple servomotor (6 V) and I thought - is Duet 3 mini too much for that? if yes, maybe you guys have any recommendations?
      o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @Arminas
        @Arminas It depends on, how you want to control them. Is synchonized gcode control required or just a simple remote access via HTML and WiFi?
        IoT-nodes can do various things. Based on a ESP32 you'll have wireless browser access.
        A solenoid might require an external circuit like a Mosfet power switch.
          dc42 administrators @Arminas
          @Arminas you could use a Duet 3 Mini but it would be overkill. If you don't need an Ethernet connection then a 5V Arduino connected to a mosfet and flyback diode to drive the solenoid would be simpler and cost less.
