What start/finish gcode uses?
i am interested in tweak start/finish .gcode script i use in slicer….
I would like to know what you use, both at the START and at the END.
In my case, i am using
START
[[language]] G90 ;Movimientos absolutos G1 X0 Y0 ; Moverse al centro de la cama en X e Y G1 Z50 ; Moverse a 50 mm de altura
ENDING
[[language]] G1 E-30 F2000 ; E G90; Distancias Absolutas G0 Z450 F1800 ; E M106 S0 ; turn off cooling fan M104 S0 ; turn off extruder M140 S0 ; turn off bed M84 ; disable motors
Thanks
I use different ones depending on the hot end and filament. Here is an example but unless you have a mixing hot end, it probably won't be much use
Start g.code
G28; home all
; layer_height =[layer_height]
G10 P0 S185 R185 ; Set tool 0 operating and standby temperatures
G10 P1 S185 R185 ; Set tool 1 operating and standby temperatures
G10 P2 S185 R185 ; Set tool 2 operating and standby temperatures
G10 P3 S185 R185 ; Set tool 3 operating and standby temperatures
G1 Y364 F9000 ; move to Y =max
T0; select a tool 0
M109 S185 ; complete tool heating to 185 and wait.
M83; Set extruder to relativeEnd gcode
G10 ; retract
G91 ; set relative positioning
G1 Z5 F240 ; move bed down 5mm
G90 ; back to absolute positioning
G1 X165 Y300 F9000; Move head to rear
M300 S2500 P500 ; play beep to indicate end of print
G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures
G10 P1 S-273 R-273 ; Set tool 1 operating and standby temperatures
G10 P2 S-273 R-273 ; Set tool 2 operating and standby temperatures
G10 P3 S-273 R-273
M106 S0 ; turn off print cooling fan
M140 S0; Turn off bed
