Firmware 3.50.rc.4 stops working
Hi @gloomyandy,
It seems that the BTT guys experience a similar problem:
https://github.com/jcheger/BTT-SB22xx-undervoltage-reset-issue/blob/main/README.mdI ground my my hotend and my extruder now, just in case.
Cheers, Chriss
@Chriss That BTT issue is just similar in effect, but may not be related at all in cause (if you go back to the original issue, grounding the metalwork on the effector does not fix it for everyone). Also, in the BTT case it seems to be mostly about their toolboards, the issue is not happening (AFAICT) with BTT main control boards. So I believe it's a red herring.
@oliof maybe…. But what else could be the root cause of the problem than? Software may be bad or a mechanical/electrical problem. Anyway, I want to strike out things which are easy to solve.
Have you tried running the same gcode file again to see if i stops at the same point?
Please share a M122 report after each reset.
Also please share your config set.
