    DSF 3.5.1 Install Error: Failed to upload
    Firmware installation
    • CCS86undefined
      CCS86
      I am trying to upgrade from 3.5.0b4 to 3.5.1, and have already gotten the firmware and DWC installed on my Maestro.
      But, every time I try to upload the DSF, it fails on this file:
      Failed to upload DuetControlServer.SPI.Communication.FirmwareRequests.AbortFileHeader.html
      Your Duet rejected the HTTP request: could not create file
      I'm actually not even sure if this is a requisite installation.
        Which board? SBC mode? Can you share a M122?
        CCS86undefined 1 Reply Last reply Reply Quote 0
        • CCS86undefined
          CCS86 @Phaedrux
          @Phaedrux
          Maestro. No SBC.
          m122
          RepRapFirmware for Duet 2 Maestro version 3.5.1 (2024-04-19 14:40:37) running on Duet Maestro 1.0
          Board ID: 08DJM-956DU-LLMS4-7J9F6-3SN6Q-KBM2Q
          Used output buffers: 1 of 26 (22 max)
          Static ram: 23480
          Dynamic ram: 67060 of which 0 recycled
          Never used RAM 22236, free system stack 178 words
          Tasks: NETWORK(1,ready,26.2%,202) ACCEL(6,nWait 5,0.0%,345) HEAT(3,nWait 5,0.1%,338) Move(4,nWait 5,0.0%,310) TMC(4,nWait 5,1.8%,109) MAIN(1,running,64.3%,791) IDLE(0,ready,7.7%,30), total 100.0%
          Owned mutexes:
          Last reset 00:35:22 ago, cause: software
          Last software reset at 2023-06-16 21:25, reason: User, Gcodes spinning, available RAM 17184, slot 2
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          MCU temperature: min 39.2, current 40.7, max 41.1
          Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/224/0, gc cycles 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, read errors 0, write errors 1, ifcnt 22, reads 26058, writes 9, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: standstill, read errors 0, write errors 1, ifcnt 22, reads 26058, writes 9, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: standstill, read errors 0, write errors 1, ifcnt 22, reads 26058, writes 9, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: standstill, read errors 0, write errors 1, ifcnt 17, reads 26061, writes 6, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: standstill, read errors 0, write errors 1, ifcnt 13, reads 26061, writes 6, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: not present
          Driver 6: not present
          Date/time: 2024-04-19 13:19:01
          Slowest loop: 475.41ms; fastest: 0.19ms
          === Storage ===
          Free file entries: 9
          SD card 0 detected, interface speed: 15.0MBytes/sec
          SD card longest read time 2.2ms, write time 96.0ms, max retries 0
          DMs created 83, segments created 3, maxWait 1895171ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          no step interrupt scheduled
          Moves shaped first try 0, on retry 0, too short 0, wrong shape 4, maybepossible 0
          === DDARing 0 ===
          Scheduled moves 10, completed 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          Bed heaters 0 -1, chamber heaters -1 -1, ordering errs 0
          Heater 0 is on, I-accum = 0.2
          Heater 1 is on, I-accum = 0.2
          Movement locks held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is doing "M190 R60" in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Q0 segments left 0
          Code queue 0 is empty
          === Filament sensors ===
          check 340708 clear 5979184
          Extruder 0 sensor: ok
          === Network ===
          Slowest loop: 1020.20ms; fastest: 0.01ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          Interface state active, link 100Mbps full duplex
          Socket states: 1 5 5 2 2 2
            No SBC means no need for DSF.
            If you have access to DWC, just upload the release zip file and you're done.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.1/Duet2and3Firmware-3.5.1.zip
            • chrishammundefined
              chrishamm administrators @CCS86
              @CCS86 That file is part of the DSF code documentation, it shouldn't be part of any release ZIP. What file were you trying to upload?
              Duet software engineer
              • CCS86undefined
                CCS86
                Sounds like operator error!
                I could have sworn in the past, I had to upload a 3rd file when upgrading RRF and DWC. I thought it was DSF, but must have been something else.
                  droftarts administrators @CCS86
                  @CCS86 the Maestro IAP (In App Programmer) file, named “Duet2_SDiap32_Maestro.bin”, is the third required file. The IAP files weren’t in the 3.5.1 release initially, but they are now. Not sure if they made it into the release zip though.
