    DWC not displaying the duex2 and duex driver temperatures
    • appjawsundefined
      appjaws
      I have the following settings in config:-
      ; Thermistors and heaters System
      M308 S10 Y"mcu-temp" A"MCU" ; defines sensor 10 as MCU temperature sensor
      M308 S11 Y"drivers" A"Duet stepper drivers" ; defines sensor 11 as stepper driver temperature sensor
      M308 S12 Y"drivers-duex" A"Duex stepper drivers" ; for Duet 2 WiFi/Ethernet with DueX2/5, defines sensor 12 as DueX2/5 stepper driver temps
      The mcu temp works as expected but S11 and S12 show 0.
      Do I need any other settings?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • gloomyandyundefined
        gloomyandy @appjaws
        @appjaws See: https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_configuring_mcu_temp#:~:text=Stepper driver temperature - The Trinamic,of 0C%2C 100C and 130C.
        Stepper driver temperature - The Trinamic drivers used on Duets do not report temperature, rather they report one of: temperature OK, temperature overheat warning, and temperature overheat error. RRF translates these three states into readings of 0C, 100C and 130C.
        The stepper drivers on the Duet2 board do not really have a temperature, just a report if they get too hot. So 0 is normal.
        appjawsundefined 1 Reply Last reply Reply Quote 0
        • appjawsundefined
          appjaws @gloomyandy
          @gloomyandy
          Thanks
          Simplify3D 5.1.2
