    Odd appearance in M291 window
    Duet Web Control
    • OwenDundefined
      OwenD
      This isn't causing me an issue, so just reporting it out of interest.
      It only seems to have started since 3.5.1
      Don't recall seeing it at any time previous.
      I have an M291 during my bed soaking period that pops up every few seconds as a notice of what's going on.
      The relevant section of code is
      while  ((heat.heaters[0].active - var.target) > (sensors.analog[8].lastReading)) && (global.BedHasSoaked = false)
      	if heat.heaters[0].state != "active"
      		echo "Bed heater no longer active.  Soaking cancelled"
      		M99
      	M291 R{"Soaking Bed (" ^ heat.heaters[0].active ^ "C)  Please wait"} P{"Bed temp = " ^  heat.heaters[0].current ^ " : Edge temp = " ^ (sensors.analog[8].lastReading)}  S0 T2
      	G4 S4
      I've just noticed that for a fraction of a second, you can see an emergency stop button in the corner.
      T3P3Tonyundefined chrishammundefined 2 Replies Last reply Reply Quote 2
      • T3P3Tonyundefined
        T3P3Tony administrators @OwenD
        @OwenD good spot I see that as well.
        www.duet3d.com
        • chrishammundefined
          chrishamm administrators @OwenD
          @OwenD Thanks for reporting this, I'm going to fix it in v3.5.2.
          Duet software engineer
