    My printer reboots alone…. 3.5.1
    Beta Firmware
    reboot error update
    10
    32
    1.5k
    • Aurimasundefined
      Aurimas @gloomyandy
      @gloomyandy
      yes - I believe it was on.
      even though after all these restarts I might have lost the track
      here is another crash report
      m122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: PA279-4N6KL-K65J0-409N0-4Z02Z-HWYBD
      Used output buffers: 20 of 40 (36 max)
      Static ram: 103232
      Dynamic ram: 122532 of which 12 recycled
      Never used RAM 15640, free system stack 182 words
      Tasks: NETWORK(2,nWait 7,14.4%,208) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.0%,310) CanReceiv(6,nWait 1,0.1%,772) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,1.4%,102) MAIN(1,running,83.1%,651) IDLE(0,ready,0.0%,30) AIN(4,delaying,0.9%,260), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 39:07:39 ago, cause: software
      Last software reset at 2024-05-11 16:34, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 11100, slot 1
      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0047d803 BFAR 0x0000001c SP 0x20011ff0 Task NETW Freestk 483 ok
      Stack: 2002c610 20030848 200014e8 00000000 2003322f 0002ff99 0002feac 610f0000 0002ff85 00000000 00000000 00000000 20030854 00000800 2002c5f8 2002c5f8 00000002 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 46b8173e
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 140859060, completed 140859060, timed out 0, errs 0
      MCU temperature: min 22.9, current 23.1, max 23.5
      Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 2, read errors 0, write errors 0, ifcnt 81, reads 62161, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 106, read errors 0, write errors 0, ifcnt 81, reads 62161, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 45, reads 62161, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 64, read errors 0, write errors 0, ifcnt 83, reads 62161, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 66, read errors 0, write errors 0, ifcnt 84, reads 62161, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: standstill, SG min 56, read errors 0, write errors 0, ifcnt 84, reads 62161, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 6: standstill, SG min 68, read errors 0, write errors 0, ifcnt 83, reads 62161, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2024-05-13 07:41:49
      Slowest loop: 32.79ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 20
      SD card longest read time 3.7ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      Scheduled moves 1, completed 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1, chamber heaters 4 -1 -1 -1, ordering errs 0
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000803
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 6162, received 27379, lost 0, errs 0, boc 0
      Longest wait 6ms for reply type 6024, peak Tx sync delay 261, free buffers 26 (min 25), ts 3419/3419/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 20.35ms; fastest: 0.06ms
      Responder states: MQTT(0) HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.1beta6
      MAC address e8:68:e7:e1:4e:a5
      Module reset reason: Power up, Vcc 3.41, flash size 2097152, free heap 33128
      WiFi IP address 192.168.1.110
      Signal strength -56dBm, channel 2, mode 802.11n, reconnections 0
      Clock register 00002001
      Socket states: 0 0 3 0 0 0 0 0
      Australian design and build large scale 3d printers
      https://aurarum.com.au
      CorvoConVundefined 1 Reply Last reply Reply Quote 0
      • CorvoConVundefined
        CorvoConV @Aurimas
        @Aurimas I have just now the same reset reason just now....
        • gloomyandyundefined
          gloomyandy @CorvoConV
          @CorvoConV Please see https://forum.duet3d.com/post/338744 if you were running with M122 P500 S0 set please post the output from M122.
            dc42 administrators @gloomyandy
            @CorvoConV @Aurimas thanks for reporting this and for posting M122 reports.
            The reports you have provided suggest that you are seeing the same issue as this one https://github.com/Duet3D/RepRapFirmware/issues/935. The crash location is slightly different but there are a number of common factors:
            • Duet 3 Mini WiFi board
            • Network task has crashed
            • A network transaction has probably taken place just before the crash
            • The crash appears to be have been caused by a zero word having been written to a value on the stack
            To help me make further connections, please report the list of preferred languages you have selected in your browser. If you are running Chrome then you can get this information by going to Settings, then Languages, and you will see the list in the Preferred Languages box.
            PS - the strange values in the task total field of the M122 report are not an issue. The value overflows if M122 hasn't been run for more than about 90 minutes since the machine was started or M122 was last run. I will fix this in the next release.
            dc42 created this issue in Duet3D/RepRapFirmware
            closed Regular crashes on Duet 3 Mini WiFi #935
            DonStaufferundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
            • DonStaufferundefined
              DonStauffer @dc42
              @dc42 FWIW I think this happens on my Duet 2 WiFi.
              gloomyandyundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 said in My printer reboots alone…. 3.5.1:
                Somewhat relieving that this looks like it's manifesting on others as well. I haven't had any of these issues after i started to mainly use OrcaSlicer for DWC connections (no DWC tabs open in chrome on the desktop), with the occational Chrome(android) connection through my phone to check in on a ongoing print.
                  gloomyandy @DonStauffer
                  @DonStauffer said in My printer reboots alone…. 3.5.1:
                  Last software reset at 2024-05-14 20:51, reason: AssertionFailed, Gcodes spinning, available RAM 920, slot 0
                  That looks like a different problem to me than the ones being reported here. What is happening when you have this problem? @dc42 may be able to confirm and may have a better idea what is causing the assert.
                  DonStaufferundefined 1 Reply Last reply Reply Quote 0
                    dc42 administrators @DonStauffer
                    @DonStauffer I've moved your post to a new topic because it is not the same issue. See https://forum.duet3d.com/topic/35722/duet-2-assertion-failure-rrf-3-5-1.
                      DonStauffer @gloomyandy
                      @gloomyandy The printer just reboots unexpectedly. It never used to happen, but now it happens a couple times per day, starting around the time I upgraded from 3.4.1 (I think; whatever the last full release was).
                      • dc42undefined dc42 referenced this topic
                        All, please see https://forum.duet3d.com/topic/36689/random-hard-fault-resets-on-duet-3-mini-wifi and provide any additional reports there. I am locking this thread.
                        • dc42undefined dc42 locked this topic
