    BLDC &encoder driver for a large laser cutter?
    CNC
    • flopesundefined
      flopes
      Do you suggest a BLDC &encoder driver for me to build a large laser cutter?
      The motor should spin at about 100Hz and 1k ticks encoder
      It seems the ODrive is not an option, according to some postings here
      Thanks
      • o_lampeundefined
        o_lampe @flopes
        @flopes There is the STM B_G431B_ESC board, which works with hardware-encoder for medium power BLDC motors.
        It can be flashed with simpleFOC, which allows you to control the motor via step/dir interface by gcode directly or UART messages (for constant speed or torque use cases)
