    Error: in file macro line 7: G1: insufficient axes homed
    • Joelundefined
      Joel
      I'm getting this error at the end of every print,
      I am not sure where it is coming from. I made a very simple gcode file,
      G90
      G1 Z10 X175 Y175 F6000
      M84
      It does its thing and then gives me the same error.
      Any ideas where I should look?
      Thanks
      Joel
      OwenDundefined 1 Reply Last reply Reply Quote 1
      • OwenDundefined
        OwenD @Joel
        @Joel
        What is in your stop.g?
        Joelundefined 1 Reply Last reply Reply Quote 0
        • Joelundefined
          Joel @OwenD
          @OwenD
          There is a G1 move at line 7 but I thought stop.g was only called when you cancel a print, not at the end of a print.
          This is a new behavior for 3.5.1.
          OK - I renamed my stop.g to something else and the error went away. I'm not sure how to fix this. Why is this now being called at the end of a print when in 3.4.x it seemed not to be ( never saw this error before )?
          • Joelundefined
            Joel @Joel
            OK, I think I found more stuff wrong in the way I'm doing things. My slicer is set up to move the head to where I want it after a print, then I turn off the steppers. I found that turning off the steppers is causing the issue.
            What I will do is remove the ending moves from my slicer and let stop.g do it.
            Still not sure why I did not see this in 3.4
            So far about every update exposes an issue, so far it has been things I have set up that are not quiet right.
            So now 4 printers later and numerous clean ups ( each new printer started with the previous printers files ), I think my scripts and setups are zeroing in on being right.
            Thanks
            Joel
            • Joelundefined Joel marked this topic as a question
            • Joelundefined Joel has marked this topic as solved
            • OwenDundefined
              OwenD @Joel
              @Joel
              You need to read the change logs before doing any update
              In this case
              When a print file completes normally then file stop.g is run automatically even if the print file did not end with a M0 command
              https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-351-stable-changes-since-346
              Joelundefined 1 Reply Last reply Reply Quote 1
              • Joelundefined
                Joel @OwenD
                @OwenD
                That's easy enough to say, the change lists are sometimes quite long. Unless you have something in mind or it happens to pop in your head while "browsing" through those lists that something might affect you...
                Basically, you don't know, what you don't know.
                In any case, your pointer was right and I was able to sort it out.
                Thanks!
