    magnetic rotating filament sensor does not save the settings
    Filament Monitor
    • Simon 4undefined
      Simon 4
      I do have the magnetic rotating filamentsensor, it works as it should but the settings which I tell him are not saved when I turning off the printer.
      i.e. procentage reduced to 40% to 160% and check distance 5mm, it always has the devault value.
      every new start it responds this
      what I am doing wrong
      next question is: in which file is this included if I want to copy this to several other identical printers ?
      infiniteloopundefined 1 Reply Last reply Reply Quote 0
      • paralepsisundefined
        paralepsis
        Your settings should be in config.g.
        Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
        • infiniteloopundefined
          infiniteloop @Simon 4
          @Simon-4
          There are no settings saved on shutdown at all. Instead, the Duet is configured after booting the firmware, that’s what the config.g is for. So, if you know which parameters you need to initialise your filament sensor with, insert a line with M591 D0 … in your config.g just as @paralepsis says.
          • Simon 4undefined
            Simon 4
            OK, that´s so obious that I did not thought about it. Can't see the forest for the trees.
            I thought because of statistics which the sensor sends back with M591 D0 there has to be an internal memory.
              @Simon-4
              In fact, there is - well, kind of. Apart from the RAM which the DUETs use to maintain, calculate and organise data during operation, some specific settings can be written to the SD card for permanent storage. These then can be recalled when the system starts up again. See the GCodes M500: Store parameters and M501: Read stored parameters for details.
              The problem with this mechanism is that the settings are typically defined in config.g - which is a good way to understand how your printer is set-up - but are then altered by the contents of a second file (config-override.g) which may introduce some level of confusion. So, many of the Duet users prefer to edit the config.g instead of relying on this mechanism, just to keep all settings in a single place.
              • droftartsundefined droftarts marked this topic as a question
              • droftartsundefined droftarts has marked this topic as solved
