    SPI connection reset on Duet 3 Mini 5+
    472
    • sgomesundefined
      sgomes
      Hey folks!
      I've been setting up my Duet 3 Mini5+ in SBC mode through initial setup, configuration, and calibration, and it's been working absolutely fine so far — until today, when it started failing with SPI connection reset errors out of nowhere, persisting after multiple full reboots. The errors sometimes occur during initial bed probing (using a Prusa SuperPINDA 5V probe), and sometimes only during a print.
      I've been monitoring the MCU and SBC (Raspberry Pi 4) temperatures and they seem fine, and PSU voltage seems stable as well (using a Mean Well LRS-350-12). The Raspberry Pi 4 is powered by its own, official adapter. I've also ensured there are no cables in the vicinity of the ribbon connector that could be creating any sort of EM interference.
      Perhaps the M122 output can offer some clues? Thank you in advance for any help, as I'm quite stumped 😞
      M122 output follows:
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (SBC mode)
      Board ID: 75ZD9-UQ6KL-K65J0-409N0-3J02Z-H2B5T
      Used output buffers: 1 of 40 (17 max)
      Static ram: 103232
      Dynamic ram: 106468 of which 0 recycled
      Never used RAM 31716, free system stack 208 words
      Tasks: SBC(2,ready,3.1%,433) HEAT(3,nWait 1,0.0%,356) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,339) TMC(4,nWait 6,0.8%,111) MAIN(2,running,89.9%,737) IDLE(0,ready,5.3%,30) AIN(4,delaying,0.9%,265), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:00:04 ago, cause: reset button
      Last software reset at 2024-05-13 16:39, reason: User, Gcodes spinning, available RAM 31716, slot 1
      Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 4800, completed 4800, timed out 0, errs 0
      MCU temperature: min 34.6, current 35.2, max 35.4
      Supply voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 444, read errors 0, write errors 1, ifcnt 197, reads 223, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 320, read errors 0, write errors 1, ifcnt 198, reads 223, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 46, read errors 0, write errors 1, ifcnt 145, reads 222, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 126, reads 222, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 62, read errors 0, write errors 1, ifcnt 145, reads 223, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2024-05-13 18:18:18
      Cache data hit count 10098753
      Slowest loop: 3.91ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 20
      SD card 0 not detected, interface speed: 0.0MBytes/sec
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      === DDARing 1 ===
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000000
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 39, received 0, lost 0, errs 21868, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 24/0/0
      Tx timeouts 0,0,23,0,0,14 last cancelled message type 30 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 32874/658
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x0d3f4
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server version 3.5.1 (2024-04-19 16:20:35, 32-bit)
      HTTP+Executed:
      > Executing M122
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 2
      Full transfers per second: 39.47, max time between full transfers: 59.6ms, max pin wait times: 866.7ms/5.8ms
      Codes per second: 0.24
      Maximum length of RX/TX data transfers: 4496/1196
        droftarts administrators @sgomes
        @sgomes You will be better off posting the log from the SBC. See https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#troubleshooting for troubleshooting these kinds of errors.
        If you have been connecting components, it's possible that either something is generating a lot of interference, or is shorting the 5V or 3.3V power, turning of the Duet. Your M122 says the last reset was 4 seconds ago; if it continually resets, look at your wiring.
        sgomesundefined 1 Reply Last reply Reply Quote 0
        • sgomesundefined
          sgomes @droftarts
          @droftarts Thank you for taking a look! 🙇
          The fault doesn't continually happen; I just got lucky that one time and managed to run M122 very shortly after a reset.
          I enabled SBC-side logging and captured a reset partway through the first layer on a print. Here's a snippet that starts a few moves before the failure:
          May 14 17:29:45 CR10S-DHR DuetControlServer[2226]: [debug] File: Sent G1 X257.978 Y128.238 E331.82272, remaining space 56, needed 48
          May 14 17:29:45 CR10S-DHR DuetControlServer[2226]: [debug] File: Sent G1 X177.394 Y47.654 E337.85979, remaining space 8, needed 48
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] File: Finished code G1 X257.978 Y114.724 E253.67491 =>
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] File: Finished code G1 X257.978 Y115.625 E253.72264 =>
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] File: Starting code G1 X176.493 Y47.654 E337.90752
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] Processing G1 X176.493 Y47.654 E337.90752
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] File: Starting code M73 P2 R255
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] Processing M73 P2 R255
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] File: Sent G1 X176.493 Y47.654 E337.90752, remaining space 56, needed 48
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] File: Sent M73 P2 R255, remaining space 16, needed 40
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] Requesting update of key inputs, seq 586 -> 588
          May 14 17:29:48 CR10S-DHR DuetControlServer[2226]: [debug] Updated key inputs
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X190.008 Y47.654 E258.81475
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X189.107 Y47.654 E258.86248
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y116.526 E264.02209
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y117.427 E264.06982
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X188.206 Y47.654 E269.29693
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X187.305 Y47.654 E269.34466
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y118.328 E274.63927
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y119.229 E274.687
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X186.404 Y47.654 E280.04911
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X185.503 Y47.654 E280.09684
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code M73 P1 R255
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y120.13 E285.52645
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y121.031 E285.57418
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X184.602 Y47.654 E291.07129
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X183.701 Y47.654 E291.11902
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y121.932 E296.68362
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y122.833 E296.73135
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X182.8 Y47.654 E302.36345
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X181.899 Y47.654 E302.41118
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y123.734 E308.11078
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y124.635 E308.15851
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X180.998 Y47.654 E313.92561
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X180.097 Y47.654 E313.97334
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y125.536 E319.80794
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y126.436 E319.85562
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X179.196 Y47.654 E325.75769
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X178.295 Y47.654 E325.80542
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y127.337 E331.77499
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X257.978 Y128.238 E331.82272
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X177.394 Y47.654 E337.85979
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code G1 X176.493 Y47.654 E337.90752
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] File: Cancelled code M73 P2 R255
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [warn] SPI connection has been reset
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [info] Aborted job file
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [info] Starting macro file config.g on channel Trigger
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] Trigger: Starting code M550 P"CR10S-DHR" (macro code)
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] Trigger: Starting code M905 P"2024-05-14" S"17:29:51" (macro code)
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] Intercepting code M550 P"CR10S-DHR" (Pre) via IPC#12
          May 14 17:29:51 CR10S-DHR DuetControlServer[2226]: [debug] Trigger: Starting code ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi (macro code)
          Is any of this useful in debugging the issue? It seems suspicious that there are gcodes being cancelled before the SPI connection reset message, but I don't know enough to understand what's happening here 😕
            @sgomes one for @chrishamm
            • sgomesundefined
              sgomes @droftarts
              @droftarts Thank you again for your help!
              While I can't run a test print right now, I think I may have figured it out, thanks to your earlier hypotheses. And if so, it's a doozy...
              I think that the issue is that the extruder wire loom was too close to the X axis stepper motor, and the motor may have been causing EM interference that propagated back to the board, resetting it during certain moves...
              I tried manually moving the X axis back and forth while the loom was distant from the motor and I didn't observe a single reset. But if I set it back to where it was (right up against the housing), sure enough, I was easily able to get a reset after a bit.
              This would explain why the resets only ever happened during moves, and why they started all of a sudden — I must have moved the electronics box slightly, and with it the loom.
              I'll be sure to follow up tomorrow, when I get the chance to run a full test print with the loom away from the X stepper!
              sgomesundefined 1 Reply Last reply Reply Quote 1
              • sgomesundefined
                sgomes @sgomes
                @droftarts @chrishamm Unfortunately, it looks like I was wrong 😞 EM interference on the extruder wires from the motor doesn't seem to be the issue.
                The test print has failed with a similar error, in a different location, during the first layer. Log follows:
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Finished code G1 X257.978 Y248.068 E780.18079 =>
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Starting code G1 X257.978 Y258.88 E974.09475
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] Processing G1 X257.978 Y258.88 E974.09475
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Finished code G1 X257.978 Y248.969 E780.22852 =>
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Finished code M73 P7 R239 =>
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Starting code G1 X257.978 Y259.781 E974.14248
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Starting code G1 X42.022 Y43.824 E990.32117
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] Processing G1 X257.978 Y259.781 E974.14248
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] Processing G1 X42.022 Y43.824 E990.32117
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Sent G1 X257.978 Y258.88 E974.09475, remaining space 120, needed 48
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Sent G1 X257.978 Y259.781 E974.14248, remaining space 72, needed 48
                May 15 08:43:25 CR10S-DHR DuetControlServer[390]: [debug] File: Sent G1 X42.022 Y43.824 E990.32117, remaining space 24, needed 48
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X45.398 Y36.388 E796.15429
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X45.071 Y36.388 E796.17161
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code M73 P8 R239
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X44.548 Y36.44 E796.19945
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y249.87 E812.18886
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y250.771 E812.23659
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X43.841 Y36.633 E828.27901
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X43.341 Y36.901 E828.30906
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X43.266 Y36.96 E828.31412
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y251.672 E844.39958
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y252.573 E844.44731
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.791 Y37.386 E860.56835
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.711 Y37.47 E860.57449
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.416 Y37.912 E860.60264
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y253.474 E876.75177
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y254.375 E876.7995
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code M73 P8 R238
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.146 Y38.543 E892.96886
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.058 Y38.958 E892.99133
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.029 Y39.327 E893.01094
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y255.276 E909.18907
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y256.177 E909.2368
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.022 Y40.22 E925.41549
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.022 Y41.121 E925.46322
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y257.078 E941.64191
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y257.979 E941.68964
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.022 Y42.022 E957.86833
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.022 Y42.923 E957.91606
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code M73 P8 R237
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y258.88 E974.09475
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X257.978 Y259.781 E974.14248
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] File: Cancelled code G1 X42.022 Y43.824 E990.32117
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [warn] SPI connection has been reset
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [info] Aborted job file
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [info] Starting macro file config.g on channel Trigger
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] Trigger: Starting code M550 P"CR10S-DHR" (macro code)
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] Trigger: Starting code M905 P"2024-05-15" S"08:43:29" (macro code)
                May 15 08:43:29 CR10S-DHR DuetControlServer[390]: [debug] Trigger: Starting code ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi (macro code)
                • chrishammundefined
                  chrishamm administrators @sgomes
                  @sgomes Can you please share the M122 output after the reset? Your first dump doesn't show an unexpected reset reason or a disconnect event.
                  What kind of microSD card are you using in the SBC? If it is only a standard microSD card, consider replacing it with an A1- or A2-rated microSD card.
                  Duet software engineer
                  • sgomesundefined
                    sgomes @chrishamm
                    @chrishamm Thank you, @chrishamm!
                    Here's the M122 dump, although it doesn't look very useful either to my untrained eye:
                    M122
                    Static ram: 103232
                    Tasks: SBC(2,ready,2.2%,431) HEAT(3,nWait 1,0.0%,353) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,334) TMC(4,delaying,0.8%,111) MAIN(2,running,95.1%,762) IDLE(0,ready,0.9%,30) AIN(4,delaying,0.8%,265), total 100.0%
                    Last reset 00:00:29 ago, cause: reset button
                    Error status: 0x00
                    MCU revision 3, ADC conversions started 30188, completed 30187, timed out 0, errs 0
                    MCU temperature: min 37.1, current 37.2, max 38.3
                    Driver 0: standstill, SG min 184, read errors 0, write errors 1, ifcnt 36, reads 1550, writes 14, timeouts 0, DMA errors 0, CC errors 0
                    Driver 1: standstill, SG min 176, read errors 0, write errors 1, ifcnt 35, reads 1550, writes 14, timeouts 0, DMA errors 0, CC errors 0
                    Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 31, reads 1550, writes 14, timeouts 0, DMA errors 0, CC errors 0
                    Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 30, reads 1551, writes 13, timeouts 0, DMA errors 0, CC errors 0
                    Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 31, reads 1550, writes 14, timeouts 0, DMA errors 0, CC errors 0
                    Date/time: 2024-05-15 08:43:58
                    Cache data hit count 67000041
                    Slowest loop: 3.95ms; fastest: 0.15ms
                    === Storage ===
                    === DDARing 0 ===
                    === DDARing 1 ===
                    === CAN ===
                    Messages queued 265, received 0, lost 0, errs 140194, boc 0
                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 150/0/0
                    Tx timeouts 0,0,149,0,0,114 last cancelled message type 30 dest 127
                    RX/TX seq numbers: 28084/2593
                    HTTP+Executed:
                    > Executing M122
                    Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 14
                    Full transfers per second: 3.23, max time between full transfers: 932.0ms, max pin wait times: 880.8ms/15.0ms
                    Codes per second: 0.02
                    Maximum length of RX/TX data transfers: 4436/1204
                    As for the SD card, it's a 16GB SanDisk Edge, with a class 10, A1 rating, identical to this one.
                    droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                      @sgomes said in SPI connection reset on Duet 3 Mini 5+:
                      @chrishamm Is the number of TfrRdy pin glitches significant? I had a quick look at some other M122 reports in SBC mode, and they all report 0 for this.
                        @sgomes @droftarts I find it rather odd that the disconnect counters do not show anything, if there had been a protocol error, at least one of the counters should have been increased. Did you reset the board straight after the SPI connection reset? Or do you have a physical reset button connected anywhere? I'd suggest to disconnect that (if present) or check if the physical reset button does not make intermittent contact, because a reset button press is reported as the board's last reset reason.
                        If that does not change anything, you could replace the ribbon cable and/or shield it, and check if that helps.
                        • sgomesundefined
                          sgomes @chrishamm
                          @chrishamm said in SPI connection reset on Duet 3 Mini 5+:
                          @sgomes @droftarts Did you reset the board straight after the SPI connection reset?
                          No, I'm afraid all I did was run M122 once I got a chance. The resets happen on their own, and as far as I can tell they're simultaneous with the fault. Or, to put it a different way, I suppose the fault manifests as a reset, with similar logs to the ones I've shared here every time.
                          I don't have a physical reset button, no; I didn't even know that it was possible to hook one up. I've never used the one built into the board either, since I control everything via the SBC.
                          I'm using the stock ribbon cable that came with the Duet 3 Mini 5+. If I'm to try replacing it, should I get a short, standard 26-pin ribbon cable, or should I look for something more specific?
                          I'm happy to try some shielding as well, but I don't have any know-how there. Should I wrap some sort of wire mesh around the ribbon cable and earth said mesh?
                            @sgomes And the built-in reset button next to the USB jack has enough clearance?
                            • sgomesundefined
                              sgomes @chrishamm
                              Yes, there should plenty of clearance. I have the board mounted vertically with that side on the bottom, but I did leave a 2mm gap between the board and the case floor.
                              Could the reset button get triggered because of EM interference? Just in case, I've rerouted a few wires inside the electronics box and will attempt some more test prints later today.
                              • sgomesundefined
                                sgomes @sgomes
                                @droftarts @chrishamm Good news! I just managed to finish a 4.5hr print, which came out flawlessly 🙂 I'd never been able to print that long without a failure, so I'm hopeful that's the end of that!
                                Edit: And I've now finished a 12hr print as well!
                                Perhaps the wires I moved (for the 5V inductive probe, IIRC) were somehow triggering the reset button through EM interference?
                                Oh, and for good measure, I ran M122 after the print finished, and it reported TfrRdy pin glitches: 67. Hopefully that won't be a problem in the future, but I suppose I can always try a new ribbon cable if it comes to that.
                                Thank you both for your help! 🙂
                                • droftartsundefined droftarts referenced this topic
