    plugin DuetRff ultimaker cura
    Duet Web Control
    • paolozampini1973undefined
      paolozampini1973
      I tried all the plugins but none of them work with version 5.3. How can you solve the problem, thanks
        droftarts administrators @paolozampini1973
        @paolozampini1973 Any reason you don't want to update Cura? The current version is 5.7.1. As far as I know the 'Duet RepRapFirmware integration' plugin works, though I haven't tried it as I mostly use PrusaSlicer. You can get old versions of the plugin from: https://github.com/Kriechi/Cura-DuetRRFPlugin/
        paolozampini1973undefined 1 Reply Last reply Reply Quote 0
          paolozampini1973 @droftarts
          @droftarts I also tried the other older plugins but the problem persists, the version I have, if you noticed, is the interprise; from the Street shot However, I repeat even with older versions of plugins and the problem remains
          • oliofundefined
            oliof @paolozampini1973
            @paolozampini1973 if you use the enterprise version of Cura, your organisation's administrator needs to whitelist plugins. As far as I know, this may not be available on the free enterprise tier, which has zero advantage over just standalone Cura.
            Please be aware that there is a bug with Cura 5.7.x and the RRF plugin https://github.com/Kriechi/Cura-DuetRRFPlugin/issues/53 which has not been addressed as far as I can see.
            oliof created this issue in Kriechi/Cura-DuetRRFPlugin
            closed Cura 5.7 beta crashes when trying to upload a file via the plugin #53
              paolozampini1973 @oliof
              @oliof Thanks everyone for the information
