    Since update… this message when Homing
    • peirof
      peirof last edited by
      Since i have updated to 1.20, when i Homing, i have this message in console
      [[language]]
      Error: Attempt to move the head of a Delta or SCARA printer before homing it
      Why?
        I presume your printer is a delta. What commands do you have in your homing file?
        • Dougal1957
          Dougal1957 last edited by
          I get the same behaviour as well David but it just continues and the warning goes away after a few secs so doesn't bother me
          ; homedelta.g
          ; generated by RepRapFirmware Configuration Tool on Fri Jul 07 2017 14:49:07 GMT+0100 (BST)
          ; Use relative positioning
          G91
          ; Move all towers to the high end stopping at the endstops (first pass)
          ;*** Slow homing has been configured. Change F600 to F6000 below when your configuration is working
          G1 X585 Y585 Z585 F6000 S1
          ; Go down a few mm
          G1 X-5 Y-5 Z-5 F6000 S2
          ; Move all towers up once more (second pass)
          G1 X10 Y10 Z10 F360 S1
          ; Move down a few mm so that the nozzle can be centred
          G1 Z-5 F6000
          ; Switch back to absolute positioning and go to the centre
          G90
          G1 X0 Y0 F6000
          bed.g start M561
          G1 X0 Y0
          ; Home all towers
          G28
          the G1 at the start is the cause
          Doug
            @Dougal1957:
            bed.g start M561
            G1 X0 Y0
            ; Home all towers
            G28
            Doug
            Just to be clear, that would be the G1 X0 Y0 command in bed.g, which would provoke that message if you run auto delta calibration without homing the machine first.
            • Dougal1957
              yes indeed although I have a G28 at the end of my Config.g as well so as I say it doesn't come up then (just tested it But I have seen the error in Version prior to 1.20).
              • peirof
                Hi…
                My bed.g
                [[language]]
                ; bed.g; bed.g file for RepRapFirmware, generated by Escher3D calculator
                ; 16 points, 6 factors, probing radius: 140, probe offset (0, 0)
                M561                        ; clear any bed transform, otherwise homing may be at the wrong height
                G31 X0 Y0                    ; don't want any probe offset for this
                G28                            ; home the printer
                G30 P0 X0.00 Y140.00 Z-99999 H0
                G30 P1 X89.99 Y107.25 Z-99999 H0
                G30 P2 X137.87 Y24.31 Z-99999 H0
                G30 P3 X121.24 Y-70.00 Z-99999 H0
                G30 P4 X47.88 Y-131.56 Z-99999 H0
                G30 P5 X-47.88 Y-131.56 Z-99999 H0
                G30 P6 X-121.24 Y-70.00 Z-99999 H0
                G30 P7 X-137.87 Y24.31 Z-99999 H0
                G30 P8 X-89.99 Y107.25 Z-99999 H0
                G30 P9 X0.00 Y70.00 Z-99999 H0
                G30 P10 X60.62 Y35.00 Z-99999 H0
                G30 P11 X60.62 Y-35.00 Z-99999 H0
                G30 P12 X0.00 Y-70.00 Z-99999 H0
                G30 P13 X-60.62 Y-35.00 Z-99999 H0
                G30 P14 X-60.62 Y35.00 Z-99999 H0
                G30 P15 X0 Y0 Z-99999 S6
                G1 X10 Y10 F5000
                M500
                  I suspect the problem lies in your homedelta.g file.
