    Controlling general purpose solenoids
    • jwiloundefined
      jwilo
      I need to control a simple low current solenoid on/off, without PWM control with a Duet 3 Mini 5+.
      I have connected it to OUT_5, and configured OUT_5 using
      M950 P5 C"solenoid"
      And attempted to switch it on/off using
      M42 P5 S1
      and
      M42 P5 S0
      But the solenoid does not energise. I can confirm 24V (my VIN voltage) is present on OUT5+, and that the solenoid works when powered with 24V on the bench, so it must just be something to do with my configuration.
      Hope somebody can help, many thanks.
        dc42 administrators @jwilo
        @jwilo I think he meant:
        M950 P5 C"out5"
        jwiloundefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @jwilo
          @jwilo said in Controlling general purpose solenoids:
          M950 P5 C"solenoid"
          'solenoid' isn't a valid pin name.
          Try M950 P5 C"solenoid".
          Try M950 P5 C"out5".
          See https://docs.duet3d.com/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-or-gpioservo-pin
          • jwiloundefined
            jwilo @droftarts
            @droftarts Thanks Ian, not sure I understand your reply. The bit I don't understand, if "solenoid" is not a valid pin name, why does your example use it too?
            I've read the docs for M950, but must not be wrapping my head around it.
            dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
              M950 P5 C"out5"
              • jwiloundefined
                jwilo @dc42
                @dc42 Perfect! Thank you, that's the key I was missing. I thought the P value referred to which output you're using, and the name was a name you wanted to assign to the pin.
                I see now that P refers to the output you're creating, i.e. P1 is some solenoid, P2 might be a light etc, and the name is the name of the pin you want to map it to, great - all working now, thanks!
                • jwiloundefined jwilo marked this topic as a question
                • jwiloundefined jwilo has marked this topic as solved
                  Sorry! Copy/paste failure on my phone!
                  • jwiloundefined
                    jwilo @droftarts
                    @droftarts No problem, thank you!
                    • jwiloundefined jwilo referenced this topic
