Error: Pop(): stack underflow on Aux
Noticed I keep getting an error message showing up on the PanelDue. It states "Error: Pop(): stack underflow on Aux" This also shows up on the console if I have DWC already open.
This usually happens when I do some command on a PanelDue like Extrusion or home, or some other movement command. Then when I start a Macro, I get this error message pop-up. The Macro appears to run though, its just an annoyance message. I usually see this after I'm manually priming the extruder, and then run my macro to set the filament position prior to starting a print job.
Duet 3 Mini 5+ Mini5plus 3.5.1
Duet Software Framework DSF 3.5.1
Duet Web Control DWC 3.5.1
PanelDue 3.5.0 (4-wire connection only)And yes, I am running a Duet 3 Mini 5+ in SBC mode with a PanelDue. I like the responsiveness of DWC from a Raspberry Pi 4, and the flexibility of going wired or wireless without any config change. It's also very interesting that the PanelDue can see and control the Duet 3 Mini 5+ even after I command the SBC to shutdown, but all the config is on the Raspberry Pi 4 with no MicroSD card in the Duet 3.
I've also seen the occasional message about slowing polling down, but that's only on the console of the PanelDue and not a pop-up message.
