    Check network connection and switch Wi-Fi to AP mode on Duet 3
    Gcode meta commands
    346
    • Nazarundefined
      Nazar
      I am hoping to get some assistance with creating a macro for my Duet 3 mainboard. The macro should do the following:
      1. Check if there is an active network connection (either Ethernet or Wi-Fi)
      2. If no network connection is established, enable the Access Point (AP) mode on the Duet 3's Wi-Fi module
      This Macro is called from config.g through runonce.g:
      echo >"0:/sys/runonce.g" "M98 P""0:/sys/networktest.g"""
      However, when attempting to run this macro, I am encountering an error message that says "SPI timeout".
      I would greatly appreciate any help or guidance on how to properly write this macro and resolve the SPI timeout error at line 17 (M589).
      Thank you
      while network.interfaces[0].actualIP = "0.0.0.0" && network.interfaces[1].actualIP = "0.0.0.0" && iterations < 30
        G4 S1
      if network.interfaces[0].actualIP != "0.0.0.0" || network.interfaces[1].actualIP != "0.0.0.0"
        M99
        abort
      M552 I0 S0
      G4 S1
      M552 I1 S-1
      G4 S2
      M552 I1 S0
      G4 S1
      M589 S"Printer" P"1234567890" I192.168.0.1
      G4 S1
      M552 I1 S2
      M291 S2 R"Connection was not established" P"WiFi module was automatically switched to Access Point Mode"
      • T3P3Tonyundefined
        T3P3Tony administrators @Nazar
        @Nazar do you get SPI timeout when running the macro normally, not via runonce?
        What happens if you run each step of the macro by itself, at which point do you get SPI timeout?
        www.duet3d.com
        Nazarundefined 1 Reply Last reply Reply Quote 0
        • Nazarundefined
          Nazar @T3P3Tony
          @T3P3Tony
          Dear Tony,
          Thank you for your reply, I have added echo commands to the script and ran it as a separate macro from DWC, the machine was not able to send the M589 command, the WiFi module did not switch to AP mode as was commanded and I have manually restarted it.
          During the test machine was connected through WiFi and I was testing network.interfaces[0] (Ethernet)
          Please let me know if there is any other test I should perform.
          Thank you for your help!
          The Macro:
          echo >"0:/macros/report.txt" "Start"
          var it = 0
          ;while network.interfaces[0].actualIP = "0.0.0.0" && network.interfaces[1].actualIP = "0.0.0.0" && iterations < 30
          while network.interfaces[0].actualIP = "0.0.0.0" && iterations <= 30
            set var.it = var.it + 1
            echo >>"0:/macros/report.txt" "1st Loop Iteration: "^var.it
            G4 S.1
          echo >>"0:/macros/report.txt" "1st Loop Out"
          ;if network.interfaces[0].actualIP != "0.0.0.0" || network.interfaces[1].actualIP != "0.0.0.0"
            echo >>"0:/macros/report.txt" "IF - Network Connected"
            M99
            abort
          else
            echo >>"0:/macros/report.txt" "Else - Network not Connected"
          echo >>"0:/macros/report.txt" " "
          echo >>"0:/macros/report.txt" "After IF"
          M98 P"0:/sys/led/statusoff.g"
          M98 P"0:/sys/led/dimmwhite.g"
          M98 P"0:/sys/led/red.g"
          M552 I1 S-1
          echo >>"0:/macros/report.txt" "Line 35 "^result
          M552 I1 S0
          echo >>"0:/macros/report.txt" "Line 37 "^result
          M552 I1 S2
          echo >>"0:/macros/report.txt" "Line 39 "^result
          M552 I0 S0
          echo >>"0:/macros/report.txt" "Line 44 "^result
          G4 S1
          M552 I1 S-1
          echo >>"0:/macros/report.txt" "Line 48 "^result
          G4 S2
          M552 I1 S0
          echo >>"0:/macros/report.txt" "Line 52 "^result
          G4 S1
          echo >>"0:/macros/report.txt" "Line 56 "^result
          G4 S1
          M552 I1 S2
          echo >>"0:/macros/report.txt" "Line 60 "^result
          report.txt:
          Start
          1st Loop Iteration: 1
          1st Loop Iteration: 2
          1st Loop Iteration: 3
          1st Loop Iteration: 4
          1st Loop Iteration: 5
          1st Loop Iteration: 6
          1st Loop Iteration: 7
          1st Loop Iteration: 8
          1st Loop Iteration: 9
          1st Loop Iteration: 10
          1st Loop Iteration: 11
          1st Loop Iteration: 12
          1st Loop Iteration: 13
          1st Loop Iteration: 14
          1st Loop Iteration: 15
          1st Loop Iteration: 16
          1st Loop Iteration: 17
          1st Loop Iteration: 18
          1st Loop Iteration: 19
          1st Loop Iteration: 20
          1st Loop Iteration: 21
          1st Loop Iteration: 22
          1st Loop Iteration: 23
          1st Loop Iteration: 24
          1st Loop Iteration: 25
          1st Loop Iteration: 26
          1st Loop Iteration: 27
          1st Loop Iteration: 28
          1st Loop Iteration: 29
          1st Loop Iteration: 30
          1st Loop Iteration: 31
          1st Loop Out
          After IF
          Line 35 0
          Line 37 0
          Line 39 0
          Line 44 0
          Line 48 0
          Line 52 0
          Line 56 2
          Line 60 0
            droftarts administrators @Nazar
            @Nazar I think it's the second part of the macro that you're having problems with? These are the commands, in order, that your macro is doing. I've removed the echo commands, and added comments:
            M552 I1 S-1 ; turn off WiFi (no pause after)
            M552 I1 S0 ; turn on WiFi to idle (no pause after)
            M552 I1 S2 ; turn on WiFi to AP
            M552 I0 S0 ; disable Ethernet
            G4 S1 ; pause
            G4 S2 ; pause
            M552 I1 S0
            G4 S1 ; pause
            M589 S"Printer" P"1234567890" I192.168.0.1 ; configure AP
            G4 S1 ; pause
            M552 I1 S2 ; turn on WiFi in AP mode
            I think you're doing these in the wrong order, which is why the M589 command fails ("Line 56" result is "2", which is an error). Try this sequence (I don't have a 6HC with WiFi adapter to test, unfortunately):
            M552 I0 S0 ; disable Ethernet (no pause after needed)
            G4 S2 ; pause
            G4 S2 ; pause
            G4 S2 ; pause
            I tend to leave a 2 second pause between changing WiFi module status, to be on the safe side.
            Also, in the first part of your macro, you are only waiting 0.1 seconds between each loop, so 30 iterations is only 3 seconds to get an IP address. You may want to give it a bit longer.
            • Nazarundefined
              Nazar @droftarts
              Dear @droftarts,
              Thank you for your reply and advice regarding the M552 commands order, I have changed the script accordingly and rerun the test. Unfortunately, it didn't work, so I have added echo to see where it failed. It failed at the same place as before at the M589 command line.
              Thank you for your advice regarding the wait time to obtain the IP address, I set it to 0.1 sec on purpose to speed up the process of testing.
              var it = 0
                G4 S.1
                M99
                abort
              else
              echo >>"0:/macros/report.txt" "After LED"
              echo >>"0:/macros/report.txt" "Result: "^result
              G4 S2 ; pause
              G4 S2 ; pause
              G4 S2 ; pause
              Start
              1st Loop Out
              After LED
              Result: 0
              Result: 0
              Result: 0
              Result: 2
              Result: 0
                @Nazar Please step through the commands I posted, sending them one by one in the console. Please post any error messages that are reported.
                • Nazarundefined
                  Nazar @droftarts
                  @droftarts Thank you for your reply and trying to help!
                  Here is a console screenshot from Pronterface:
                  All responses from turning machine ON. Unfortunately we can see that macro doesn't work.
                  Disconnected.
                  Connecting...
                  Printer is now online.
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Done!
                  WiFi is disabled.
                  Executing runonce.g...
                  Network stopped
                  Error: Failed to configure access point parameters: SPI timeout
                  Turn off the current WiFi mode before selecting a new one
                  Done!
                  Error: Cannot delete file 0:/sys/runonce.g because it is open
                  RepRapFirmware for Duet 3 MB6HC is up and running.
                  >>> m552i0
                  SENDING:M552I0
                  Ethernet is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                  >>> m552i1
                  SENDING:M552I1
                  WiFi module is being started
                  >>> m552i1
                  SENDING:M552I1
                  Sending the same commands manually through Pronterface:
                  SENDING:M552I0
                  >>> m552i1
                  SENDING:M552I1
                  >>> m552i1
                  SENDING:M552I1
                  >>> M552 I0 S0
                  SENDING:M552 I0 S0
                  >>> M552 I1 S-1
                  SENDING:M552 I1 S-1
                  WiFi module stopped
                  >>> M552 I1 S0
                  SENDING:M552 I1 S0
                  WiFi module started
                  SENDING:M589 S"Printer" P"1234567890" I192.168.0.1
                  >>> M552 I1 S2
                  SENDING:M552 I1 S2
                  WiFi module is providing access point Printer, IP address 192.168.0.1
                  Sending commands manually works.
                  Macro that is used to test the network:
                  ;echo >"0:/macros/report.txt" "Start"
                  var it = 0
                  ;while network.interfaces[0].actualIP = "0.0.0.0" && iterations <= 30
                    ;echo >>"0:/macros/report.txt" "1st Loop Iteration: "^var.it
                    G4 S1
                  ;echo >>"0:/macros/report.txt" "1st Loop Out"
                    ;echo >>"0:/macros/report.txt" "IF - Network Connected"
                    M99
                    abort
                  else
                    ;echo >>"0:/macros/report.txt" "Else - Network not Connected"
                  ;echo >>"0:/macros/report.txt" " "
                  ;echo >>"0:/macros/report.txt" "After LED"
                  ;echo >>"0:/macros/report.txt" "Result: "^result
                  G4 S2 ; pause
                  G4 S2 ; pause
                  G4 S2 ; pause
                  Thank you for all the help! I hope to resolve this ASAP.
                    dc42 administrators @Nazar
                    @Nazar does the macro work if you invoke it manually instead of from runonce.g ?
                    • Nazarundefined
                      Nazar @dc42
                      @dc42, thank you for your prompt reply, I highly apreciate it!
                      Macro runs automatically after machine’s restart
                      Done!
                      WiFi is disabled.
                      Network stopped
                      Done!
                      Calling Macro through Pronterface
                      >>> M98 P"0:/sys/networktest.g"
                      SENDING:M98 P"0:/SYS/NETWORKTEST.G"
                      WiFi module stopped
                      - Connection was not established -
                      Send M292 to continue
                      Calling Macro through Pronterface but before turning off WiFi and Ethernet
                      >>> m552i0s0
                      SENDING:M552I0S0
                      >>> m552i1s-1
                      SENDING:M552I1S-1
                      WiFi module stopped
                      Disconnected.
                      Unfortunately neither worked.
