    Error: meta command: Too many indices
    Gcode meta commands
    496
    • DonStaufferundefined
      DonStauffer
      What does this error mean? Very much hoping it doesn't mean arrays can only have 4 subscripts or fewer. Maybe it means I didn't create the array with enough depth for the subscripts I tried to use on it?
      DonStaufferundefined 2 Replies Last reply Reply Quote 0
        DonStauffer @DonStauffer
        @DonStauffer This ran successfully with no error 6 times, then the 7th time the Duet 2 WiFi rebooted; Memory leak?
        var Inner = vector(2, vector(2, vector(2, vector(2, 0))))
        var Middle = vector(2, vector(2, vector(2, vector(2, var.Inner))))
        var Outer = vector(2, vector(2, vector(2, vector(2, var.Middle))))
        var Middle1 = var.Outer[0][0][0][0]
        var Inner1 = var.Middle1[0][0][0][0]
        set var.Inner1[0][0][0][0] = 1
        set var.Middle1[0][0][0][0] = var.Inner1
        set var.Outer[0][0][0][0] = var.Middle1
        var Middle2 = var.Outer[0][0][0][0]
        var Inner2 = var.Middle2[0][0][0][0]
        echo var.Inner2[0][0][0][0]
        Since I've started using arrays I've noticed that whether or not an error displays, if there's a problem the Duet seems to "get tired of it" and suddenly reboot doing something which has run several times with or without problems. After that, I typically have to cycle the power on the Duet for things to work properly, even things which are not related to the problem. Basically the system becomes unstable until a power cycle. Even M999 doesn't help.
          @DonStauffer 5/21/2024, 2:11:00 PM M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1 (2024-04-19 14:40:46) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-9T6BU-FG3SN-6JKD0-3S06Q-9AY7D
          Used output buffers: 3 of 26 (25 max)
          Static ram: 23256
          Dynamic ram: 75848 of which 0 recycled
          Never used RAM 11184, free system stack 172 words
          Tasks: NETWORK(1,ready,10.3%,215) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,359) DUEX(5,nWait 5,0.0%,19) MAIN(1,running,89.1%,695) IDLE(0,ready,0.5%,29), total 100.0%
          Owned mutexes:
          Last reset 00:04:47 ago, cause: software
          Last software reset at 2024-05-21 14:06, reason: AssertionFailed, Gcodes spinning, available RAM 11208, slot 1
          Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20002654 Task MAIN Freestk 1210 ok
          Stack: 00000162 00468815 004073c7 2001b3ec 00406afd 0000000e 2001b3e8 00000001 2001b3e8 2001b3dc 00410f05 2001b3e8 00410f0f 2001b400 00406b1f 0000000e 2001b3fc 00000001 2001b3fc 2001b3f0 00410f05 2001b3fc 00410f0f 2001b414 00406b1f 0000000e 2001b410
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 42.9, current 43.8, max 44.6
          Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1428/328, gc cycles 121
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min n/a
          Driver 1: standstill, SG min n/a
          Driver 2: standstill, SG min n/a
          Driver 3: standstill, SG min n/a
          Driver 4: standstill, SG min n/a
          Driver 5: standstill, SG min n/a
          Driver 6: standstill, SG min n/a
          Driver 7: standstill, SG min n/a
          Driver 8: standstill, SG min n/a
          Driver 9: standstill, SG min n/a
          Driver 10:
          Driver 11:
          Date/time: 2024-05-21 14:10:59
          Slowest loop: 10.34ms; fastest: 0.19ms
          === Storage ===
          Free file entries: 9
          SD card longest read time 8.5ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          no step interrupt scheduled
          Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
          === DDARing 0 ===
          Heater 1 is on, I-accum = 0.0
          Movement locks held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is doing "G4 P{var.DaemonPeriod}" in state(s) 0 0, running macro
          Q0 segments left 0
          Code queue 0 is empty
          === Filament sensors ===
          check 0 clear 1639403
          Extruder 0 sensor: no data received
          Extruder 1 sensor: no data received
          === DueX ===
          Read count 1, 0.21 reads/min
          === Network ===
          Slowest loop: 11.43ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          === WiFi ===
          Interface state: active
          Firmware version 2.1.0
          MAC address 84:f3:eb:83:47:be
          Module reset reason: Power up, Vcc 3.36, flash size 4194304, free heap 42972
          WiFi IP address 192.168.1.130
          Signal strength -45dBm, channel 11, mode 802.11n, reconnections 0
          Clock register 00002002
            Phaedrux Moderator @DonStauffer
            @DonStauffer said in Error: meta command: Too many indices:
            Is that repeatable?
            DonStaufferundefined 3 Replies Last reply Reply Quote 0
              DonStauffer @Phaedrux
              @Phaedrux Repeatable in the sense that if you run it over and over, the reboot will happen, and so far it has always been less than 10 runs. But not always 7. I just made it fail in 2 runs.
                @Phaedrux This macro was a stress test, of course. I don't need an array 12 levels deep. I was going for 6 so I can combine some of my global data to make the global namespace less cluttered. But I decided if the strategy failed, more dimensions would make it fail sooner.
                  @Phaedrux This one I just ran 50 times in a row with a 1 second delay, correct results, no error and no reboot:
                  var Outer = vector(2, vector(2, var.Inner))
                  var Inner1 = var.Outer[0][0]
                  set var.Outer[0][0] = var.Inner1
                  var Inner2 = var.Outer[0][0]
                    dc42 administrators @DonStauffer
                    @DonStauffer see https://github.com/Duet3D/RepRapFirmware/issues/1008 for a known bug when using the 'set' command with multiple array indices. We are currently testing a fox in preparation for release 3.5.2.
                    dc42 created this issue in Duet3D/RepRapFirmware
                    closed Bug: setting elements of nested arrays sometimes goes wrong #1008
                    DonStaufferundefined 1 Reply Last reply Reply Quote 0
                      DonStauffer @dc42
                      @dc42 Oh, the same as the other one I ran into? I can usually eventually find a way around it. Maybe this test case will help. I was able to write two macros, one of which reliably works, the other reliably doesn't.
                      I'm wondering, though: At least with explicit subscripts, going over 4 seems to always fail. Is that expected, or part of the bug? Is there a designed limit to the number of subscripts, apart from this issue? I looked and none is documented.
                        @DonStauffer I can provide you with an internal build to try when we have tested the fix some more.
                          DonStauffer @dc42
                          @dc42 If I can be useful, I'm happy to help any way I can.
                          dc42undefined 3 Replies Last reply Reply Quote 0
                            @DonStauffer currently up to 5 array indices should be supported.
                              @DonStauffer I just noticed that in some places 5 are allowed, in other places 4. I'll make it consistent.
                                @DonStauffer I've put an internal build for Duet 2 at https://www.dropbox.com/scl/fo/xoi07h62s8y73fumtdnfm/AGJ2rkQE833Umf_-9YXbitU?rlkey=7ymwbzg9vc8go203g1ind34er&dl=0. It should allow 5 array indices everywhere and fix the issue with assigning array elements when multiple indices are used.
                                • gloomyandyundefined gloomyandy referenced this topic
                                  DonStauffer @dc42
                                  @dc42 With this 3.5.1+3 update I haven't seen array corruption at all. I am having spontaneous reboots whose precise location in code seems variable. Diagnostics show an out of memory condition which I didn't see before: About how much memory do I start out with for global variables?
                                  M122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1+3 (2024-05-21 20:58:33) running on Duet WiFi 1.02 or later + DueX5
                                  Used output buffers: 3 of 26 (26 max)
                                  Static ram: 23304
                                  Dynamic ram: 75856 of which 0 recycled
                                  Never used RAM 11128, free system stack 184 words
                                  Tasks: NETWORK(2,nWait 6,11.9%,220) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,345) DUEX(5,nWait 5,0.0%,20) MAIN(1,running,87.5%,678) IDLE(0,ready,0.5%,29), total 100.0%
                                  Owned mutexes:
                                  Last reset 00:04:18 ago, cause: software
                                  Last software reset at 2024-05-23 16:44, reason: OutOfMemory, Gcodes spinning, available RAM 8, slot 2
                                  Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20002590 Task MAIN Freestk 1156 ok
                                  Stack: 20019850 004106fb 00000000 00400247 00000000 00000000 00000020 00400299 00000018 20019638 20002614 00000000 2000260c 004601c1 00000000 00412bed 20019638 20002614 2000b854 00000000 20019638 20002614 2000b7f0 00439e09 0000000c 00000000 00000000
                                  Error status: 0x04
                                  Aux0 errors 0,0,0
                                  MCU temperature: min 42.9, current 43.3, max 44.5
                                  Supply voltage: min 24.0, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/35, heap memory allocated/used/recyclable 2048/1144/0, gc cycles 113
                                  Driver 10:
                                  Driver 11:
                                  Date/time: 2024-05-23 16:48:18
                                  Slowest loop: 15.09ms; fastest: 0.19ms
                                  === Storage ===
                                  === DDARing 0 ===
                                  Q0 segments left 0
                                  check 0 clear 1452769
                                  === DueX ===
                                  Read count 1, 0.23 reads/min
                                  === Network ===
                                  Slowest loop: 8.49ms; fastest: 0.00ms
                                  HTTP sessions: 2 of 8
                                  === WiFi ===
                                  Module reset reason: Power up, Vcc 3.36, flash size 4194304, free heap 42968
                                  Signal strength -51dBm, channel 11, mode 802.11n, reconnections 0
                                    DonStauffer @dc42
                                    @dc42 OK, I'm sure I know what's going on now.
                                    Your array subscript fix worked.
                                    The remaining problem where my machine would reboot spontaneously with M122 showing an "OutOfMemory" reason was actually some leftover debugging code which I didn't realize was causing a macro call nesting depth of 8. I knew the maximum depth is 7. Rather than getting a message about the depth, the innermost call worked sometimes and not others, and the reboot happened during the nested call sometimes and outside of it other times.
                                    So, I broke the macro call nesting depth limit but the RRF response could be called "ill-behaved."
                                    EDIT: I believe the array subscript issue is solved, and I haven't seen array corruption since, after extensive testing. The OutOfMemory reboot problem tricked me. It's still there, but it just didn't show itself as frequently, and even less predictably than with nesting > 7. This one is frustrating. I have no reason to believe it has anything to do with the array corruption issue. But the reboots are so unpredictable it's hard to find the cause.
                                      @DonStauffer thanks. From your M122 report I can see that the Out Of Memory error was caused not by excessive expression nesting but when trying to create a new variable. Unfortunately there is very little free RAM on Duet 2 in some configurations, so it's not possible to create a lot of variables, especially ones that occupy a lot of space i.e. arrays and strings.
                                        DonStauffer @dc42
                                        @dc42 It seems like the problem was initializing an array element to null, then later assigning an array value to it. There was no error message, but when I changed that the spontaneous reboots stopped.
                                        My global arrays contain just under 400 integers. My estimate is total global data is around 1.5kb assuming 4-byte integers.
                                        Right now everything appears to be running correctly. If I had any concern, it's just that debugging random reboots is a challenge that takes time. Error messages are usually easier. I'm happy with how things are working right now.
                                          @DonStauffer thanks for the update. My guess is that when the reboot happened, your array assignment was causing a new heap block to be allocated because there was insufficient space in the existing one(s) to accommodate the array. Running M122 just before the failing array assignment would likely confirm this. I'll add a Github issue to see if we can check for sufficient free memory before we try to allocate a new heap block. https://github.com/Duet3D/RepRapFirmware/issues/1013
                                          PS - the maximum depth to which macros may be nested is 10, Each additional nesting requires some memory to be allocated.
                                          open Check for sufficient free memory before allocating a new heap block #1013
                                            DonStauffer @dc42
                                            @dc42 I got rid of about half my array elements by restructuring it, and for the first time, 100% of the reboots stopped. So fundamentally, it seems like I have between 1kB and 1.5kB of global space to play with total, or else I start getting a mess. In other words, I was running out of memory, but instead of sending a message, it slammed into a brick wall. So all the other stuff was probably just rearranging where and when the memory ran out.
