    (solved) Flickering LEDs and then dim
    1
    1
    277
    • giostarkundefined
      giostark
      Hi all ,
      i know maybe I should not open this 3d , but to me this was enough singular so I have to report the success of the finding...
      The smart effector the last year at one point it started to flicker/dimming . To me was strange some wiring malfunction just because I tried and checked so many time that all was correctly connected ... Frustrated at one point I give up. Then ... a sparkle... Do you want see that the Super Lube (grease) suggested to be used with the magnetic rods have inside some mineral that make it conductive? Nailed. I used some alcohol with cotton fioc to clean between the rods on the smart effector and magically it start to work as expected.
      To me this was happened because the hot chamber raised the lube temperatures making it melt a little.
