    Temperature increase in duet 3 mini wifi
    • Poloundefined
      Polo
      HI all
      What is the maximum temperature I can reach with duet3 min. I can go up to 250 F ( hotend)but some filament require more. is there a setting I can manipulate to increase. I don't not much experience.
      Thanks Much for your help !!
      jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet @Polo
        @Polo Hi you can change your maximum temperature via M143, but make sure your hotend is rated to go to the temperature you change it to, if its PTFE lined it`ll melt/burn, damage your hotend and more importantly its toxic, its also advisable to PID tune your heater.
        what hotend/printer are you using?
        https://docs.duet3d.com/User_manual/Reference/Gcodes#m143-maximum-heater-temperature
        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
