    Serial bus servo support
    Firmware wishlist
    • PenguinAkikoundefined
      PenguinAkiko
      Improve servo motor scalability, position, speed, and torque support
      Perhaps it can be controlled by commands similar to M260
      droftartsundefined PenguinAkikoundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @PenguinAkiko
        @penguinya There's already an feature request raised for this on Github, see https://github.com/Duet3D/RepRapFirmware/issues/981
        Feel free to add further comments to extend support there.
        dc42 created this issue in Duet3D/RepRapFirmware
        closed Feature: MODBUS RTU support #981
        PenguinAkikoundefined 1 Reply Last reply Reply Quote 0
          PenguinAkiko @droftarts
          @droftarts Hope it can be used on Expansion boards. The serial bus servo can be connected to IO 0 of 1LC.
          • gloomyandyundefined
            gloomyandy @PenguinAkiko
            @penguinya What "servos" are you wanting to use here? Concrete examples would make it easier for folks to better understand the request.
              PenguinAkiko @PenguinAkiko
              @gloomyandy For example, the Protocol 2.0 used by DYNAMIXEL XL330-M288-T, PWM servos cannot be used for torque control and speed control. Two-way communication can be used not only for servos maybe digital sensors or other non-real-time device control.
