    hot end current limits
    • Miss Rebekahundefined
      Miss Rebekah
      i have a Duet 2, I haven't found max current specs for the hot ends. im wanting to run two 60 watt heaters at 24V on an idex printer. so they would both be on at the same time. is this within spec? or do i need to look at ssr/mosfets?
      • deckingmanundefined
        deckingman @Miss Rebekah
        @Miss-Rebekah A quick look at duet 2 spec (https://www.duet3d.com/duetwifi) shows two extruder heater outputs at 6A each. 60 watts at 24V is 2.5 Amp so well within rated spec.
        Miss Rebekahundefined 1 Reply Last reply Reply Quote 1
          Miss Rebekah @deckingman
          @deckingman
          awesome thanks!! dont know why i couldn't find that page in my search. im surprised that little screw terminal can handle 6A.
