    Nozzles physical Z Height changes when moving horizontally (Solved)
    896
    • Saltlife716
      Saltlife716 last edited by
      Ok, I got a lot of problems fixed to where I can at least start tuning it.
      My only issue at the moment is (numbers are just an example of my problem)
      Max Z height = 390mm
      Min Z height = 0mm
      I send my nozzle to X-0, Y-0, Z-10.
      When I move my nozzle to the end of the bed (in any direction), the Z gradually raises.
      So lets say i'm at Z Height 10 in the center, if I move to the edge the Web Control still shows Z Height 10, but physically the nozzle is at Z Height 15 - 20. (again, it raises in any direction)
      Any thought?
      Config.g
      ; generated by RepRapFirmware Configuration Tool on Sun Dec 31 2017 15:54:08 GMT-0500 (Eastern Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R323.275 L450 B155 H390 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 R155 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80 Y80 Z80 E663 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M563 P0 D0 H1 ; Define tool 0
      M550 PMG v1.0 ; Set machine name
      M552 S1 ; Enable network
      M587 S"The Salt's-2G" P"TheGoodLife!0716!" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      T0 ; Select first tool
      BI v2\. 5 Heavily modded
      Duet Wifi
      E3D v6 0.20mm
      FSR autoleveling
      • Saltlife716
        Here are the stepper motors i'm using.
        https://www.aliexpress.com/item/Hot-Sale-5PCS-Wantai-Nema17-Stepper-Motor-42BYGHW609P1-Single-Flat-56oz-in-40mm-1-7A-4/1477574816.html
        Duet Wifi
        E3D v6 0.20mm
        FSR autoleveling
          Your delta printer isn't calibrated. Check that the steps/mm settings in your M92 command are correct, then calibrate your printer. See https://duet3d.com/wiki/Calibrating_a_delta_printer.
          • Martin_S
            Martin_S last edited by
            At the center is Z=10, but if you move to the edges of the bed the nozzle rises right?
            What happens if you send the nozzle back to the center? Does it go back to Z=10 or it keeps going up?
            If it goes back to Z=10 my guess is that your delta radius is way off.
            Happy new year for the ones that are close to midnight!!! 🙂
            If it ain't broke, fix it till it is =)
            • Saltlife716
              Yes the nozzle goes back to physical Z=10 when i go back to center.
              I put in all the values not 100% but extremely close. I used the RRF Configuration Tool.
              Delta Radius (R)-323.275mm. Measurement from middle of print bed to the center of the tower
              Diagonal Arm Length (L)-450mm. For this am I literally measuring center of tower to effector joint in parallel? If so it would be
              like 230ish, but when I put that in there, when I click Home all, it does the physical action of homing all,
              but then in the web control is says X-9999.9, Y-9999.9, Z-9999.9 and won't let me control anything. So i
              just put in 450mm for center of ball to ball length.
              Printable radius (B)-155mm. I'm using a 310mm print bed, so half of that is 155mm.
              Homed Height (H)-390mm. measurement from nozzle to bed (not accurate since the nozzle is changing z height when i try to
              level the bed.
              One a side note, how does one measure Maximum carriage travel? Then I look at the "hint" when you hover over it and it says "Maximum travel length in Z direction", wouldn't that be my "Homed Height"?
              I'm about to install these FSRs on here to see if it will auto calibrate and adjust those settings for me. But i'm not sure to what extent those will help. Never used them before.
              Duet Wifi
              E3D v6 0.20mm
              FSR autoleveling
              • heathmanc
                heathmanc last edited by
                Take a look at your delta radius, seems awfully large, like twice what it should be. Do an image search on google for a picture of how to measure.
                Charles
                • Saltlife716
                  Ok I see what happened. In the RRF Configuration Tool it says "Distance between the centre of your towers and the joint at the effector. So I was measuring from the center of the effector joint to the center of the tower, when from the google images i looked at it said to measure to the other center of ball. And it looks pretty even now and now raises the z height, thanks everyone!
                  Duet Wifi
                  E3D v6 0.20mm
                  FSR autoleveling
                  • Martin_S
