    Sensorless homing
    • handyandyundefined
      handyandy
      Hi, I had been getting on fine with sensorless homing with my duet3mini5 board. Both the X & Y axis were homing almost silently and ultra-repeatable with just one contact needed to work.
      However, I was getting an error message with the X-axis, it came up as...
      "Error: Pin name needed for switch type end stop on X-axis ". I don't understand this homex.g is identical to home.y (except X's and Y's! of course). Why is it asking for a pin name when it's sensorless ?
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @handyandy
        @handyandy best post your config and homing files
        handyandyundefined 1 Reply Last reply Reply Quote 0
          handyandy @jay_s_uk
          @jay_s_uk Hi, I've not uploaded files here before so I hope I'm doing it right!
          config.g
          homex.g
          homey.g
          homez.g
          homeall.g
          Whilst you are looking at these I also can't get the PanelDue to display.
          Any Ideas?
            Phaedrux Moderator @handyandy
            @handyandy said in Sensorless homing:
            It's likely these lines in your X and Y homing files
            M574 X1                                ; use stallguard for endstop
            It's missing the S3 for sensorless.
            If it's still giving you the error, search your macros for other M574 commands and make sure they have the correct syntax.
            Your M575 command in your config.g is using S0 instead of S1.
            It should be M575 P1 B57600 S1 to enable the PanelDue.
