    EXP1HCL "50.io1.out" PWM control issue
    • Panosundefined
      Panos
      Hi!
      I've successfully connected the following components:
      • 1HCL EXP-BOARD (Duet EXP1HCL rev 1.0a or earlier firmware version 3.5.2, dated 2024-06-10 13:24:59)
      • DUET 3 6HC (RepRapFirmware for Duet 3 MB6HC, version 3.4.5, hardware: Duet 3 MB6HC v1.02 or later, firmware date: 2022-11-30 19:35:23)
      I've changed the CAN BUS address to 50 and configured two output pins as PWM outputs:
      • M950 P6 C"50.io0.out"
      • M950 P7 C"50.io1.out"
        I am able to set the "50.io0.out" to any value using the following command, for example: M42 P6 S0.5.
      However, I am unable to control the "50.io1.out" as a PWM pin and can only control it as a digital output (LOW or HIGH). According to the Duet documentation, it should be possible to configure the "50.io1.out" as either I2C or PWM out.
      I've also attached a picture with the header removed to configure the pin as PWM out:
      Any idea why this might be happening?
        Phaedrux Moderator @Panos
        @Panos said in EXP1HCL "50.io1.out" PWM control issue:
        Your 6HC is on an older firmware than the expansion board. Update it to 3.5.2 to match.
        • sebkritikelundefined sebkritikel referenced this topic
