    Outputs on Duet 2
    Third-party add-ons
    357
    • Muhammedundefined
      Muhammed
      I need to use an output with 3.3V to 5V - 25mA on my Duet 2 card and found that I can only use and control the expansion pins on the same card. I believe that the amp is fine but still wondering about the maximum amp that this pins can handle? I am planning to use the heater outputs shown below.
      Is this all right? can I control these outputs as I need?
      Thanks
        What exactly are you trying to drive from those pins? They should be considered signal pins only and cannot power a heater directly.
        Muhammedundefined 1 Reply Last reply Reply Quote 0
        • Muhammedundefined
          Muhammed @Phaedrux
          @Phaedrux I need to turn on some sort of laser diode which needs an output with 3.3V to 5V and 25mA. Can't I just use them as output signals and turn them on or off when wanted? Also, to control some lights as well?
          infiniteloopundefined 1 Reply Last reply Reply Quote 0
          • infiniteloopundefined
            infiniteloop @Muhammed
            @Muhammed
            I need to use an output with 3.3V to 5V - 25mA on my Duet 2 card …
            Most of the signals on the expansion bus originate from the Atmel MCU, so they are unbuffered and have a rather limited fanout. You can look-up the specs from the data sheet of the MCU, but don’t expect them to deliver more than 10 mA at 3.3V each. I suggest to use some buffers or inverters from the 4000 or 7400 series.
            • Muhammedundefined
              Muhammed @infiniteloop
              @infiniteloop Thanks for clarifying. I guess that I misunderstood the documentation about these pinouts.
              I just need one output for max 25mA, and can only see the PS-ON/GND as a possible usable output for my laser diode?! and I need the PWM outputs for fans. if you have any recommendation will be highly appreciated. Thanks!
              • Muhammedundefined
                Muhammed @Muhammed
                @Muhammed said in Outputs on Duet 2:
                I can manage to have a spare output from the PWM FANS outputs, then I think it should be fine to use it, but I need to be careful about setting the voltage to the correct value. Will this be ok?
                  @Muhammed
                  From the lion's mouth: "The PS_ON output is a PMV40UN2 mosfet (good for up to 30V and 3A) on the Duet WiFi". So that's an N-MOSfet (switching to GND) - should be powerful enough to control (not: to power) your laser.
                  Sure, these use N-MOSfets as well, so switch whatever voltage you supply on the other side to GND. Maybe you need to provide a pull-up resistor, depending on the signal required.
                  Muhammedundefined 2 Replies Last reply Reply Quote 0
                  • Muhammedundefined
                    This post is deleted!
                    • Muhammedundefined
                      @infiniteloop Thank you so much for your reply. This will give me a push forward.
