    Adjusting PID Parameters for Best Temperature Management
    • jackzzundefined
      jackzz
      Hello Everyone 😊,
      I upgraded the printer to the Duet 2 WiFi card recently, and I'm very new to the field of 3D printing. Although Duet3D's features and community support have greatly impressed me, I've run across a small problem that I'm hoping some of you may assist me with.
      I'm having trouble getting the best temperature control by fine-tuning the PID parameters on my heated bed and hotend. I've tried the auto-tune tool and read through a number of tutorials, but my outcomes are still erratic.
      Here's a quick summary of my setup & the actions I've already taken:
      Configuring a printer:
      • Model of printer: Ender 3 Pro Duet 2 WiFi, with firmware 3.4.0
      • Hotend: 0.4 mm nozzle E3D V6
      • Bed: Regular glass-plated heated bed
      Actions Undertaken:
      • Executed the M303 command to auto-tune the bed and hotend.
      • Enter the PID values that were obtained by running the M307 command.
      • Carried out several prints to verify that the temperatures were stable.
      Problems Experienced:
      • During prints, the hotend temperature varies by +/- 2°C, which results in slight variations in print quality.
      • The temperature of the bed is comparatively constant, but it takes a while to attain the desired temperature.
      • Every now and then, I have temperature issues that cause the print to pause; I have to reset and restart.
      I also followed this: www.reddit.com/r/ControlTheory/comments/o1g6xg/any_tips_to_tune_a_pid_temperature_mlops_controller/
      I would be very grateful for any guidance on the following:
      • Are there any particular options or factors that I could be missing that could aid in regulating the temperature of the hotend?
      • Advice on how to heat the bed more quickly and steadily.
      • General best practices that may not be included in the usual guidelines for Duet 2 WiFi PID tuning.
      I've received so much encouragement from this group, and I can't wait to absorb your combined wisdom. Thank you 👍 in advance.
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @jackzz
        @jackzz did you auto tune the hotend as a heater or as a tool? if you're unsure, post the M303 command you've been using
          droftarts administrators @jackzz
          @jackzz said in Adjusting PID Parameters for Best Temperature Management:
          Update your firmware, too. Latest: https://github.com/Duet3D/RepRapFirmware/releases/latest
