    Saving M208 to config-override.g
    Using Duet Controllers
    • Kiwi 0undefined
      Kiwi 0
      Re: Saving M208 (axis min/max) values in config-override.g possible?
      Has there been a change in rep rap firmware?
      Somehow I'm getting an M208 to the config-override.
      And I don't want it. After a print (or the print is canceled) I'm not able to travel to the initial Z Max
        droftarts administrators @Kiwi 0
        @Kiwi-0 Normally M208 isn't saved to config-override.g. However, if you have used a G1 H3 move, and subsequent M500 will save M208. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m500-store-parameters
        Check your homing macros for any G1 H3 moves. These do the following:
        H3 terminate the move when the endstop switch is triggered and set the axis limit to the current position, overriding the value that was set by M208.
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g0g1-h-and-s-parameter
        Kiwi 0undefined 1 Reply Last reply Reply Quote 0
        • Kiwi 0undefined
          Kiwi 0 @droftarts
          @droftarts
          Thanks for the hint with the H3
          It was in the toolchange macro and probably a heatertuning with a M500 at the end brought it do the override...
          Thanks a lot!
