BIQU microprobe issues
@Craigrobbo said in BIQU microprobe issues:
@jay_s_uk said in BIQU microprobe issues:
@Craigrobbo ok, let's reset. Post the current code you are using.
Also, consider upgrading to 3.5.2While I have been having a play this evening, I tried your S280 commands again from your guide and this just causes very erratic behaviour, sometimes the probe deploys sometimes it doesn't then sometimes it randomly deploys and retracts on its own...
very strange.
I thought this too, was one of the first things I checked, i isolated the loom but this didnt help, also the results while random are repetable in terms of how it reacts to different commands and the timing of them
What should my M950 be?
*edit I replied to the wrong quote sorry!
Sorry, i replied to the wrong quote, I meant to reply to the next one - I did seperate the wiring to mitigate it, also tried an actual BL touch and this works fine
@Craigrobbo are you saying BLTouch works after separating out the wiring, or Microprobe, or both?
@oliof said in BIQU microprobe issues:
The BLtouch worked when the cables re within the wiring loom and the same when seperated too.
undefined Phaedrux marked this topic as a regular topic
undefined infiniteloop referenced this topic
