HTTP request timeout
After transferring the file, it will time out after printing for a few minutesCan you help me take a look
Send M122=== Diagnostics ===
RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 0JD2M-9P9DA-F0PS8-6JKDG-3S06Q-1PUV2
Used output buffers: 1 of 40 (36 max)
Static ram: 149784
Dynamic ram: 90892 of which 60 recycled
Never used RAM 109936, free system stack 184 words
Tasks: NETWORK(ready,232) ETHERNET(blocked,117) HEAT(blocked,299) CanReceiv(blocked,909) CanSender(blocked,365) CanClock(blocked,326) TMC(blocked,16) MAIN(running,1120) IDLE(ready,20)
Owned mutexes:
Last reset 00:36:25 ago, cause: power up
Last software reset at 2024-07-13 20:18, reason: User, GCodes spinning, available RAM 109520, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
MCU temperature: min 45.2, current 58.5, max 58.8
Supply voltage: min 23.6, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
Driver 0: position 0, standstill, reads 63118, writes 13 timeouts 0, SG min/max 0/0
Driver 1: position 0, standstill, reads 63113, writes 18 timeouts 0, SG min/max 0/85
Driver 2: position 0, standstill, reads 63113, writes 18 timeouts 0, SG min/max 0/84
Driver 3: position 0, standstill, reads 63113, writes 18 timeouts 0, SG min/max 0/99
Driver 4: position 0, standstill, reads 63113, writes 18 timeouts 0, SG min/max 0/86
Driver 5: position 0, standstill, reads 63121, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2024-07-24 13:57:02
Slowest loop: 5.25ms; fastest: 0.11ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 3.4ms, write time 0.0ms, max retries 0
DMs created 125, maxWait 1218ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 2, completed moves 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 8758, send timeouts 0, received 22, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 8, free buffers 48 (min 47)
=== Network ===
Slowest loop: 22.83ms; fastest: 0.02ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 2 of 8- Ethernet -
State: active
Error counts: 0 0 1 0 0
Socket states: 5 2 2 2 2 0 0 0
- Ethernet -
@fkueypmb123 maybe update your firmware to 3.5.2 and try again.
There have been some network tweaks since 3.3 beta -
@jay_s_uk
of no avail
Print for a few minutes and then restart after timeout -
@fkueypmb123 can you confirm that 3.5.2 installed ok? you can confirm with M115 or M122
@jay_s_uk What is the reason for this, that it was fine before, and I can replace this board with another machine
@fkueypmb123 ok, good luck
