M23CL no led up!
Hi to all,
i'm Angelo and i'm devoloping a printer with 6 M23CL 3 for Z, 2 for Y and 1 for X.
I first powered the engines individually to correctly configure the addresses and then connected them all to the duet3d tool distribution.They worked properly for about 30 minutes, after that all six engines stopped showing no flashing or steady LEDs and now even after a new poweup they do not give signs of life and the connection can time out. What could have happened?
No fuse on the distribution board is broken
Board 6HC v1.02
Motor M23CL no Brake v1
Tool Board Distribution 0.5vDSF 3.5.2
DWC 3.5.2
RRF 3.5.2Power supply 24V 10A
This post is deleted! -
All 6 showing no signs of life may indicate they aren't actually getting power. Can you verify that your power supply is working correctly and the motors are actually receiving power?
I see you've removed your post about a potentially burned fuse. Was that erroneous?
@Phaedrux hi!
thanks for the replay!
Yes the internal fuse burned, i don't know why!
All the other part of the printer stay up!Is not a risk put this fuse inside?
Can you show some photos of the setup and the fuse?
Have you verified your PSU?
Have you tried setting up a simplified arrangement with a single motor for testing?
