    Help with over-extrusion
    • Jman3undefined
      Jman3
      I have an Ender 3 running RepRap firmware on a Duet 3 mini 5+ and I recently installed a direct drive sprite pro extruder. I have been going through commissioning and calibration and it seems like I'm over-extruding even after the e-step calibration (423.2), and flow rate calibration (.82). I thought it might be pressure advance so I commented it out of my firmware and set it to .03 in ORCA slicer.
      I'm printing with ABS that has worked fine with the old bowden setup. See images for details.
      Any ideas on how to address this issue?
        Phaedrux Moderator @Jman3
        @Jman3 said in Help with over-extrusion:
        Are you sure the esteps are correct with your new extruder?
        Jman3undefined 1 Reply Last reply Reply Quote 0
        • Jman3undefined
          Jman3 @Phaedrux
          @Phaedrux I repeated the e step calibration 3 or 4 times so I feel pretty good about it.
          I posted the same thing on another site and someone mentioned that retraction settings can cause this same issue. I double checked my settings and I had an override on my ABS settings that was still 2mm. I lowered it to .5 then tested it last night and the print looked perfect this morning. So the issue was my retraction setting surprisingly.
