    Replacement FFC for SZP/Probe?
    • micaheliundefined
      micaheli
      Is there an online source or sales team that can assist with getting a replacement FFC? Also, are there different lengths available?
      Would love to know, and to keep a couple spare just in case.
        droftarts administrators @micaheli
        @micaheli FFC cables are readily available. You want 4-way, 0.5mm pitch, opposite side contacts, Flat Flexible cable, eg here on Mouser
        We supply cables that are 50mm and 150mm that are rated for 80C. Different lengths, and higher temperature rated FFCs are available. I'm not sure what the longest you could reliably use are.
        micaheliundefined 1 Reply Last reply Reply Quote 0
        • micaheliundefined
          micaheli @droftarts
          @droftarts Great! Thanks for the link. That help a ton. I haven't ruined mine yet, but I'm more than prepared to accept that I might. Failure is always an option.
