    MB6HC SBC Update from 3.4.6 to 3.5.2 doenst work
    Firmware installation
    • DavidG_68kg_PLAundefined
      DavidG_68kg_PLA
      Hey team,
      I'm currently about to upgrade mit MB6HC with SBC from 3.4.6 to 3.5.2 (latest stable).
      I executed via terminal:
      sudo apt update
      sudo apt upgrade
      afterwards i tried to update via M997 in the command line, but nothing happended so far:
      When i try to execute sudo apt update again, it answers:
      pi@T3000SE-L67W2:~ $ sudo apt update
      Hit:1 https://linux.teamviewer.com/deb stable InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Ign:3 https://deb.nodesource.com/node_16.x buster InRelease
      Ign:4 https://pkg.duet3d.com stable InRelease
      Hit:5 http://archive.raspberrypi.org/debian buster InRelease
      Err:6 https://deb.nodesource.com/node_16.x buster Release
        Certificate verification failed: The certificate is NOT trusted. The certifica        te issuer is unknown.  Could not handshake: Error in the certificate verificatio        n. [IP: 104.22.5.26 443]
      Err:7 https://pkg.duet3d.com stable Release
        Certificate verification failed: The certificate is NOT trusted. The certifica        te issuer is unknown.  Could not handshake: Error in the certificate verificatio        n. [IP: 134.209.94.168 443]
      Reading package lists... Done
      E: The repository 'https://deb.nodesource.com/node_16.x buster Release' no longe        r has a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disa        bled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration deta        ils.
      E: The repository 'https://pkg.duet3d.com stable Release' no longer has a Releas        e file.
      [1]+  Exit 1                  nohup /usr/bin/onboard > /dev/null 2>&1
      I googled and understand this message as "system is up to date, there is no newer version"?
      M122:
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.01 (SBC mode)
      Board ID: 08DJM-956BA-NA3TJ-6J9DD-3S46J-KA8US
      Used output buffers: 1 of 40 (15 max)
      Static ram: 153252
      Dynamic ram: 66568 of which 20 recycled
      Never used RAM 127880, free system stack 154 words
      Tasks: SBC(ready,0.9%,474) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,267) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,349) TMC(notifyWait,7.6%,90) MAIN(running,90.3%,1183) IDLE(ready,1.2%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:35:38 ago, cause: software
      Last software reset details not available
      Error status: 0x00
      Step timer max interval 136
      MCU temperature: min 19.6, current 20.1, max 20.4
      Supply voltage: min 23.5, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 11.9, current 12.0, max 12.0, under voltage events: 0
      Heap OK, handles allocated/used 99/13, heap memory allocated/used/recyclable 2048/988/800, gc cycles 28
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 904, reads 34921, writes 5 timeouts 0
      Driver 1: standstill, SG min 0, mspos 971, reads 34921, writes 5 timeouts 0
      Driver 2: standstill, SG min 0, mspos 533, reads 34921, writes 5 timeouts 0
      Driver 3: standstill, SG min n/a, mspos 8, reads 34926, writes 0 timeouts 0
      Driver 4: standstill, SG min n/a, mspos 8, reads 34926, writes 0 timeouts 0
      Driver 5: standstill, SG min n/a, mspos 8, reads 34925, writes 0 timeouts 0
      Date/time: 2024-08-08 14:14:51
      Slowest loop: 53.28ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 4, maxWait 1028961ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is doing "G4 P200" in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 18623, received 82770, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 275, free buffers 50 (min 50), ts 10346/10346/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 4116/4116
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ab5c
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server v3.4.6
      Daemon:
      Buffered code: G4 P200
      ==> 32 bytes
      Executing macro daemon.g, started by system
      Number of flush requests: 1
      > Next stack level
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 63.23, max time between full transfers: 57.5ms, max pin wait times: 65.6ms/10.2ms
      Codes per second: 2.25
      Maximum length of RX/TX data transfers: 3512/896
      Thanks a bunch!
      droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @DavidG_68kg_PLA
        @DavidG_68kg_PLA the 3.4.6 release is on the Raspberry Pi OS 'Buster', while the 3.5 release is on 'Bookworm'. You can't upgrade directly from Buster to Bookworm, there's just too many changes. We recommend backing up your configuration, then flash the Bookworm image to the RPi SD card, then restore the configuration. See https://docs.duet3d.com/en/How_to_guides/SBC_Buster_to_Bookworm
        • chrishammundefined
          chrishamm administrators @DavidG_68kg_PLA
          @DavidG_68kg_PLA It's apt upgrade that installs software packages. @droftarts is right, the distro version you're using is EOL and will no longer receive system updates.
          Duet software engineer
          Tinchusundefined 1 Reply Last reply Reply Quote 0
          • Tinchusundefined
            Tinchus @chrishamm
            @chrishamm is this possible with raspi 3 B+
            Im just flashing a brand new sd card, and foun imposible to use thje images located here:
            https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup
            If I choose the 32 bit lite version, no graphic interface is installed so my touchsecreen is pretty useless. The other image, I burned it with all posible methods, and the sdcar just doesnt boot.
            64 bit version works, but I guess I shouldnt be using that one with a raspi 3 B+
            have you checked the 32 bit version works and are not corrupted or something?
              chrishamm administrators @Tinchus
              @Tinchus I flashed the 32-bit variant on some Pis and I haven't had issues with it. See the other thread for info about your touchscreen.
