    What happened with fans conectors?
    Firmware installation
    • peirof
      peirof last edited by
      The fan controlled by temperature to FAN1, did not work, I changed and connected another fan directly to the board in FAN1 (Extract of config.g, next), and it has not worked either, raising the hotend temperature, with the addition that after a few seconds smoke has started to come out .. ..
      [[language]]
      M106 P0 S0 I0 F255 H-1; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F255 H1 T50; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F255 H1 T50; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      So with a multimeter I have measured the voltage of the connector FAN1 …. AND I MEASURED 24 V !!!!!!!!!., which I suppose this has damaged and / or burned the fan ....
      If I understand correctly, those fans are 12V, and now the connector takes 24V, I guess this will be for the update at 1.20, because as I said before I did not pass
      This is normal?
      Is there any way to get the connectors FAN0, FAN1 and FAN 2, 12V?
      Any other explanation?
        See https://duet3d.com/wiki/Connecting_and_configuring_fans. On a 24V powered printer it is normal to use 24V fans. They are readily available.
        • peirof
          :C
          Eeeeemmmmm… Old trick of polarity...
          Mistake.... No... BIG MISTAKE
          Sorry
